sequential injection stimulation using the multiphaseInterFoam
Old   September 6, 2013, 09:17
Post sequential injection stimulation using the multiphaseInterFoam
salame ama
salame is on a distinguished road
Hi, Formers:
these days, i used the multiphaseInterFoam solver for stimulating the sequential injection. but the results not OK. i think the problems emerge in the alpha setting. I want to stimulate first inject O(fluid) in the cavity, some time later, stop O and inject the M (another fluid) with the same inlet.
Relevant files below:
First, inject O.......
1 alphaair
dimensions [0 0 0 0 0 0 0];
internalField uniform 1;
boundaryField
inlet
type zeroGradient;
outlet
type inletOutlet;
inletValue uniform 1;
value uniform 1;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
2 alphaM
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
3 alphaO
boundaryField
inlet
type fixedValue;
value uniform 1;
outlet
type zeroGradient;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
4 setFields
efaultFieldValues
volScalarFieldValue alphaair 1
volScalarFieldValue alphaO 0
volScalarFieldValue alphaM 0
regions
boxToCell
box (-0.01 -0.01 0.001) (0.001 0.002 0.003);
fieldValues
volScalarFieldValue alphaO 1
volScalarFieldValue alphaair 0
Second, after injecion 0.6s, stop O and inject M, I change the alphaO and alphaM in the 0.6 result file without changing others. like:
alphaM:
internalField nonuniform List<scalar>
3620
-1.34342e-09
-1.3543e-09
boundaryField
inlet
type fixedValue;
value uniform 1;
outlet
type zeroGradient;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
alphaO:
3620
-3.24112e-10
-3.36625e-10
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
the result is (writeInterval 0.2s): 1. 0~0.8s, have no change in the alpha (O, M, air)
http://xiangce.baidu.com/picture/det...dfef5441cc5425
2, from 1s, the alpha changed
1s:http://xiangce.baidu.com/picture/det...6a113f59070475
1.2s:http://xiangce.baidu.com/picture/det...68e8d92babf075
So, can u kindly help me solve the problem?
salame is offline   Reply With Quote
Old   September 11, 2013, 09:38
Post
salame ama
the pictures
1.
2.
3.
Hi, Formers:
1 alphaair
boundaryField
inlet
type zeroGradient;
outlet
type inletOutlet;
value uniform 1;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
2 alphaM
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
3 alphaO
boundaryField
inlet
type fixedValue;
value uniform 1;
outlet
type zeroGradient;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
4 setFields
efaultFieldValues
regions
boxToCell
fieldValues
alphaM:
3620
-1.34342e-09
-1.3543e-09
boundaryField
inlet
type fixedValue;
value uniform 1;
outlet
type zeroGradient;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
alphaO:
3620
-3.24112e-10
-3.36625e-10
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
down
type symmetryPlane;
wall
type zeroGradient;
frontAndBack
type empty;
So, can u kindly help me solve the problem?[/QUOTE]
Diesel injection problem Jurek FLUENT 2 June 16, 2017 07:05
injection problem Mark New FLUENT 0 August 4, 2013 02:30
jou file command for the injection! asal FLUENT 0 June 4, 2013 05:15
On DPM injection properties. akr FLUENT 4 October 23, 2006 11:54
using injection file and parallel process Cindy Jones FLUENT 0 January 23, 2003 13:40
