2D flow around a circular cylinder case with interFoam solver |
August 31, 2013, 06:09 |
Yao Lu
Rep Power: 13 |
I'm solving a 2D flow around a circular cylinder case with interFoam solver.
Here are the geometry and BCs. 1.jpg 0/U file Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type uniformFixedValue; uniformValue constant (0.0006 0 0); } outlet { type zeroGradient; } side { type fixedValue; value uniform (0 0 0); } cylinder { type fixedValue; value uniform (0 0 0); } qianhou { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } side { type zeroGradient; } cylinder { type zeroGradient; } qianhou { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object alpha; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } side type zeroGradient; } cylinder { type zeroGradient; } qianhou { type empty; } } // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-5be49240882f Exec : interFoam Date : Aug 31 2013 Time : 16:18:13 Host : "luyao" PID : 4652 Case : /home/luyao/OpenFOAM/luyao-2.2.0/run/cylinder nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian --> FOAM FATAL ERROR: Attempt to return primitive entry ITstream : /home/luyao/OpenFOAM/luyao-2.2.0/run/cylinder/0/alpha1.boundaryField.side, line 32, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD primitiveEntry 'side' comprises on line 32 the word 'type' on line 32 the word 'zeroGradient' as a sub-dictionary From function const dictionary& primitiveEntry::dict() const in file db/dictionary/primitiveEntry/primitiveEntry.C at line 184. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Foam::primitiveEntry::dict() const in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #3 Foam::dictionary::subDict(Foam::word const&) const in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" #5 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" #7 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" #8 Foam::twoPhaseMixture::twoPhaseMixture(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::word const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libincompressibleTransportModels.so" #9 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" #10 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #11 in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/interFoam" Thanks in advance. shuoxue |
August 31, 2013, 10:33 |
Kevin Smith
Rep Power: 17 |
You are missing an open bracket. Also I'd recommend having a fixed value bc for alpha at the inlet.
January 14, 2020, 14:23 |
2d interfoam flow around a cylinder simulation.
abdinasir hashi
İs this problem solved.can you tell how you solved it .
thank you |
k-omega SST simulation of turbulent flow around a circular cylinder | DanM | OpenFOAM Running, Solving & CFD | 17 | October 13, 2016 14:29 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 14:00 |
Flow around circular cylinder | Karen | FLUENT | 5 | December 12, 2012 11:34 |
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re | lin | OpenFOAM Running, Solving & CFD | 3 | April 16, 2009 11:50 |
3D Flow over a circular cylinder | Srinivas | FLUENT | 3 | March 15, 2005 20:57 |
