A problem with porousSimpleFoam solver
Old   August 26, 2013, 03:56
Default A problem with porousSimpleFoam solver
Arjang Behnoud
AmirBaqa1987 is on a distinguished road
Hi Dear all
I've used porousSimpleFoam solver to model my case in porous media.
after running the the case in terminal when I go to case directory and open U and P files the following message appear and i can not check the answers.
There was a problem opening the file /home/arjang/Desktop/PorousSimpleFoam/20/U.
The file you opened has some invalid characters. If you continue editing this file you could corrupt this document.
You can also choose another character encoding and try again.
and I've chosen another character encoding but it didn't affect.
what is the problem?
your help is appreciated.
Best Regards,
Arjang
AmirBaqa1987 is offline   Reply With Quote
Old   August 26, 2013, 05:37
mohsen kh
m5m5kh is on a distinguished road
Hi dear Arjang
please describe your software of meshing,file format and also your problem more clearly please.
best regards
Mohsen
m5m5kh is offline   Reply With Quote
Old   August 26, 2013, 05:42
mohsen kh
I used the same solver and use gambit for meshing my case of study . for example , importing my case I used "fluent3DToFoam" for a 3d model and "fluentToFoam" for 2d model.
Old   August 26, 2013, 08:17
Arjang Behnoud
Dear Mohsen
I've generated Mesh by BlockMeshDict and I use openFoam-2.1.1
do you have any idea about my problem?
Old   October 30, 2015, 11:54
Callum
Fred1 is on a distinguished road
I have the same problem when trying to open my 0/U file did you find away to fix it?
im using openfoam 2.4.0
Fred1 is offline   Reply With Quote
[swak4Foam] Problem using swak4Foam in a modiefied solver bastil OpenFOAM Community Contributions 13 April 18, 2020 16:17
mesh.update problem in a new FSI solver ICL OpenFOAM 0 October 8, 2011 15:16
Compilation problem after modifying a solver. PetSul OpenFOAM Running, Solving & CFD 2 October 1, 2009 18:28
patching problem unsteady solver yellow-stuff Main CFD Forum 0 September 25, 2009 02:26
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 11:21
