Adding A Source Term To The Continuity Equation |
August 19, 2013, 15:41 |
Hello all,
I am looking to model fluid leakiness from brain tumor vessels into tumor tissue space in openFoam. To do this, i would like to amend the continuity equation so that it has a pressure dependent source term. I would like: divergence of velocity = (Leakiness rate constant)*(p_constant - p) Where (Leakiness rate constant) is the spatially varying value (known) that we would like to load from a data file of some type. I imagine the data file would have 4 columns where the columns correspond to x, y, z space and the leakiness value. p_constant is a constant, known value of pressure. p is the interstitial fluid pressure in a porous media that we would like to solve for. Does anyone know how to help me? I would very much appreciate a detailed outline of how i could do this. If you dont know do you have any resources that could help? Anything is appreciated |
August 20, 2013, 17:35 |
Help please!
Anyone please help! I need an answer within the next two days!
August 21, 2013, 06:29 |
Ehsan
Rep Power: 27 |
Hi
ask for that in programming Forum.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
continuity equation, pressure, source term, velocity |
UDF for source term in momentum equation | Enrico | FLUENT | 9 | May 30, 2014 12:34 |
Adding additional complex source term to BuoyantBoussinesqPisoFoam solver | pajofego | OpenFOAM Programming & Development | 2 | April 9, 2013 18:00 |
how to troduce a source term in ICOFOAM solver's equation | sawyer86 | OpenFOAM Running, Solving & CFD | 0 | July 20, 2012 12:15 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
