pisoFoam turbulent case looks like laminar case
Old   August 16, 2013, 04:31
Default pisoFoam turbulent case looks like laminar case
Vishal
inf.vish is on a distinguished road
Hi all,
I am using pisoFoam to simulate a simple turbulent flow through a pipe. I have used 2D axisymmetric wedge to perform this simulation. The pipe dimensions are Radius = 0.1m and length = 8m. Fluid used is water. Inlet velocity is 50m/s which makes the Reynold number 10^7.
The problem is that the flow looks like a laminar flow after running the case.
Can you point out what is wrong?
Also, if i want that my pipe has surface roughness then should i use nutkroughwallfunction?
inf.vish is offline   Reply With Quote
laminar and turbulent flow in two regions mozafarie FLUENT 0 March 11, 2013 14:42
Question about grids for laminar model and turbulent model Anna Tian Main CFD Forum 0 March 3, 2013 20:44
Force function for laminar case with interDyMFoam Claudio OpenFOAM Running, Solving & CFD 3 December 5, 2012 07:51
turbulent & laminar result comparison quarkz Main CFD Forum 1 November 25, 2006 06:25
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
