Simulation of Radial Fan with simpleFoam MRF
Old   August 13, 2013, 06:34
Default Simulation of Radial Fan with simpleFoam MRF
nash is on a distinguished road
hi, im new here and also in using OpenFoam. I did find good explainations of using mrf in simplefoam within this forum
I am now working on the simulation of radial fan with complex geometry including casing for the fan.
Im using snappyHexMesh for the meshing and STL file for rotor, casing and MRF Domain are being used here.
the MRF Zone are defined within the sHM and the rotors walls are inside the MRFDomain. The rotor walls and also the fluid within the MRF rotate and therefore im using simpleFoam with MRF
*--------------------------------*- C++ -*----------------------------------*\
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      binary;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
21
    frontAndBack
        type            patch;
        nFaces          0;
        startFace       23495251;
    inlet
        type            patch;
        nFaces          0;
        startFace       23495251;
    outlet
        type            patch;
        nFaces          0;
        startFace       23495251;
    lowerWall
        type            wall;
        nFaces          0;
        startFace       23495251;
    upperWall
        type            patch;
        nFaces          0;
        startFace       23495251;
    fan_rotor-mrf-02-layersides
        type            wall;
        inGroups        1(luefter);
        nFaces          9195;
        startFace       23495251;
    fan_rotor-mrf-02
        type            wall;
        nFaces          194950;
        startFace       23504446;
   fan_casing-03
        type            wall;
        nFaces          13678;
        startFace       23699396;
   fan_rotor-mrf-layer-02
        type            wall;
        nFaces          55326;
        startFace       23713074;
    fan_rotor-mrf-01
        type            wall;
        nFaces          219653;
        startFace       23768400;
    fan_casing
        type            wall;
        nFaces          120780;
        startFace       23988053;
   fan_plane
        type            wall;
        nFaces          182812;
        startFace       24108833;
   fan_inlet
        type            wall;
        nFaces          140059;
        startFace       24291645;
    fan_outlet
        type            wall;
        nFaces          7870;
        startFace       24431704;
    fan_canal
        type            wall;
        nFaces          123670;
        startFace       24439574;
    fan_cassing-outter
        type            wall;
        nFaces          0;
        startFace       24563244;
   fan_casing-mrf
        type            wall;
        nFaces          16511;
        startFace       24563244;
    fan_casing-02
        type            wall;
        nFaces          46960;
        startFace       24579755;
    fan_rotor-mrf-layer-01
        type            wall;
        nFaces          621030;
        startFace       24626715;
    mrfDomain_frameBorder-interior
        type            wall;
        nFaces          0;
        startFace       25247745;
    mrfDomain_frameBorder-interior_slave
        type            wall;
        nFaces          0;
        startFace       25247745;
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform ( 0 0 0);
boundaryField
    frontAndBack
        type            zeroGradient;
        value           uniform (0 0 0);
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    lowerWall
        type            zeroGradient;
    upperWall
        type            zeroGradient;
    "mrfDomain_.*"
    type            zeroGradient;
    "fan_rotor.*"
        type            fixedValue;
    "fan_casing.*"
        type            fixedValue;
    "fan_plane.*"
        type            fixedValue;
    "fan_outlet.*"
        type            zeroGradient;
    "fan_inlet.*"
        type            zeroGradient;
    "fan_canal.*"
        type            fixedValue;
        value           uniform (0 0 0 );
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    frontAndBack
        type            zeroGradient;
        value           uniform 0;
    inlet
        type            zeroGradient;
        value           uniform 0;
    outlet
        type            zeroGradient;
        value           uniform 0;
    lowerWall
        type            zeroGradient;
        value           uniform 0;
    upperWall
        type            zeroGradient;
        value           uniform 0;
    "fan_rotor.*"
        type            zeroGradient;
        value           uniform 0.;
    "mrfDomain_.*"
        type            zeroGradient;
    value           uniform 0;
    "fan_gehaeuse.*"
        type            zeroGradient;
        value           uniform 0.;
    "fan_ebene.*"
        type            zeroGradient;
        value           uniform 0. ;
    "fan_outlet.*"
        type            totalPressure;
    rho none;
    psi none;
    phi phi;
    gamma 0;
    p0 uniform 0;
        value           uniform 0.0;
    "fan_inlet.*"
        type            totalPressure;
    rho none;
    psi none;
    phi phi;
    gamma 0;
    p0 uniform 0;
        value           uniform 0.;
    "fan_canal.*"
        type            zeroGradient;
        value           uniform  0.;
unfortunately the simulation result seems to differ from the one using Fluent.
the velocity is twice as the velocity from the Fluent-Simulation and the pressure as well.
are there any improvements so that a good result can be generated?
using other solver etc. btw are the configurations of initial conditions okay?
thank you in advance
geometry of the fan is more likely in this fluent tutorial
https://docs.google.com/viewer?url=h...df&chrome=true
nash is offline   Reply With Quote
Old   August 15, 2013, 06:44
sorry to bother everyone here..
the problem resolved..
the problem is the dimension of the STL file for my cylinder MRFZone in mm.
since sHM always read in meter, so i need to use command surfaceConvert to my STL
Originally Posted by josp View Post
Or you can scale the stl files with surfaceConvert when you clean them
surfaceConvert in.stl out.stl -clean -scale 0.001
and run sHM again using the new STL generated from surfaceConvert and everything went fine.
check your STL file before running sHM either using surfaceCheck or view STL using Paraview.
thanks josp for your solution
Old   November 5, 2015, 11:12
Default fvOptions
zakk
arslantuf is on a distinguished road
Hello
Can I see your fvOption or MRFZones files? Which version are you using?
I have also results off from Fluent simulations
Thank you
arslantuf is offline   Reply With Quote
fan, mrf, rotor, simplefoam
Radial velocity and tangential velocity on centrifugal fan, johnnyp FLUENT 2 May 24, 2013 08:10
Problems fan simulation Rackham le rouge CFX 9 February 18, 2013 06:19
Simulation and Optimisation of centrifugal fan 3D to 2D eRzBeNgEl STAR-CCM+ 0 January 31, 2013 14:21
Fan simulation divergence ayothicfd CFX 18 July 20, 2012 06:53
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
