simplefoam omega convergence problem
Old   August 12, 2013, 05:54
Default simplefoam omega convergence problem
Pepe Perez
simplefoam is on a distinguished road
Hello, im working on a external aerodynamic 3d case with simplefoam, with the k omega sst model for the turbulence.
Ive got a question about relaxation factors, cause along the simulation, with linearupwind, i dont get the convergence of the residuals for the omega unless i get the relaxation factor to 0.001 (for omega)
How relaxation factors works?
Can I play modifying them without any restriction?
i-ve attached a figure where i get the omega relaxation factor modified from 0.01 to 0.7...and then to 0.001..
is this correct?
Thanks for your help, im quite novel and very often dont know how these things worls
simplefoam is offline   Reply With Quote
Old   August 12, 2013, 07:26
Miro
miro2000 is on a distinguished road
Hi!
I'm working on something similar. What are your boundary conditions, free stream velocity? What is your Re? Are you using wall functions?
How did you make your mesh? What is your Y+?
- miro
miro2000 is offline   Reply With Quote
Old   August 12, 2013, 10:31
Pepe Perez
HI, on BC i put fixed value, since with freestream i've never got convergence in 3d cases. y+ is about 40 or 50.
My doubts come about the relaxation factors
Old   August 12, 2013, 14:45
Miro
Well, I'm not an experienced foamer but i think 1e-3 is pretty low. But I don't think that means your solution is wrong.. However, it should not be necessary to set relaxation factor so low.
In other words, something is wrong with your case. And this is probably it:
Checking geometry...
Overall domain bounding box (-10 0 -10.3) (10 20 10.3)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (7.45683e-16 3.30144e-16 -2.68288e-16) OK.
***High aspect ratio cells found, Max aspect ratio: 804747, number of cells 23310
<<Writing 23310 cells with high aspect ratio to set highAspectRatioCells
Minimum face area = 5.51009e-09. Maximum face area = 9.67452. Face area magnitudes OK.
Min volume = 1.87009e-11. Max volume = 13.563. Total volume = 7321.49. Cell volumes OK.
Mesh non-orthogonality Max: 84.0764 average: 14.1312
*Number of severely non-orthogonal faces: 2520.
Non-orthogonality check OK.
<<Writing 2520 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.848689 OK.
Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
You should fix this first and then look for other problems (maybe in BC).
Cheers,
- miro
Old   August 13, 2013, 06:31
Pepe Perez
i think mesh is not the problem, because another case meshed very similar with snappy (ok with the mesh), gets ths same results.
anyway, is it bad to put relaxation factor on 0.01???
Swirl flow convergence problem with simpleFoam iqbalsk8 OpenFOAM Running, Solving & CFD 7 November 28, 2012 01:54
simplefoam convergence problem Matt1986 OpenFOAM Running, Solving & CFD 6 October 16, 2012 09:32
Convergence problem! Julian121 FLUENT 2 August 21, 2012 04:10
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 11:47
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
