Hari Krishnan
Rep Power: 17 ![]() |
I am trying to solving a case on flow through duct which has geometric size of 14 x 13 m rectangle with a transition of 6 x 5 m size and few obstructions in the flow path to reduce the flow. Inlet has pressure 0 and the outlet pressure is 250 pa and it is suction pressure. Modeled the geometry in mm and converted to m using transformPoints. Trying using simpleFoam Solver to run the case I have listed few of my basic queries here; 1. Does the no .of elements for the model has more than 15 lakhs would it be difficult in running the case. 2. Can we give the pressure for outlet as -250 while it’s a suction. 3. Do we need to give the inlet length and outlet length for the development length of 10times the diameter or width/thick to streamline the flow as laminar 4. Does relaxation factors and solver tolerances /rel tol should vary accordingly to the no of elements I was tried to run the case with 4 processors but it makes my PC to hang where I was running through VMBox with 6 processors assigned in the settings. My PC is Core i5 processor with 4GB RAM. Please advise me. Thank you, V. Hari Krishnan |
simplefoam, suction |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
ForcesCoeffs | ronaldo | OpenFOAM | 4 | September 14, 2009 07:11 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
