solver stops with error when using swakRadiationModelFunctionPlugin
Old   August 7, 2013, 06:24
Default solver stops with error when using swakRadiationModelFunctionPlugin
hannes
hanness is on a distinguished road
I have a small problem with the swakRadiationModelFunctionPlugin. I'm using OF 2.2.1 running a simulation with the buoyantSimpleFoam solver and the fvDOM radiation model. I wanted to have a look at Ru, Rp and Sh in order to check the energy balance and so added the following to my controlDict:
libs (
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libswakRadiationModelFunctionPlugin.so"
functions
    radiation_Rp
        type            expressionField;
        fieldName       radiationRp;
        expression      "radiation_Rp()";
        autowrite       true;
    radiation_Ru
        fieldName       radiationRu;
        expression      "radiation_Ru()";
        autowrite       true;
    radiation_radSource
        fieldName       radiationSource;
        expression      "radiation_radSource()";
        autowrite       true;
But unfortunately it only works if I delete the part referring to Ru, when this second block is included I get the following error message:
Starting time loop
Creating expression field radiationRp ...swak4Foam: Allocating new repository for sampledMeshes
swak4Foam: Allocating new repository for sampledGlobalVariables
"Loaded plugin functions for 'FieldValueExpressionDriver':"
  radiation_Rp:
    "volScalarField radiation_Rp()"
  radiation_Ru:
    "volScalarField radiation_Ru()"
  radiation_radSource:
    "volScalarField radiation_radSource()"
swak4Foam: Setting default mesh
 type:volScalarField
Creating expression field radiationRu ...
--> FOAM FATAL ERROR:
attempted assignment to self
    From function DimensionedField<Type, GeoMesh>::operator=(const DimensionedField<Type, GeoMesh>&)
    in file /opt/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude/DimensionedField.C at line 425.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM-2.2.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/opt/OpenFOAM-2.2.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  Foam::DimensionedField<double, Foam::volMesh>::operator=(Foam::DimensionedField<double, Foam::volMesh> const&) in "/opt/OpenFOAM-2.2.1/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam"
#3  Foam::swakRadiationModelPluginFunction_Ru::doEvaluation() in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswakRadiationModelFunctionPlugin.so"
#4  Foam::CommonPluginFunction::evaluateInternal(Foam::string const&, int&) in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#5  Foam::autoPtr<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::FieldValueExpressionDriver::evaluatePluginFunction<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&, parserField::location const&, int&) in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#6  parserField::FieldValueExpressionParser::parse() in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#7  Foam::FieldValueExpressionDriver::parseInternal(int) in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#8  Foam::CommonValueExpressionDriver::parse(std::string const&, Foam::word const&) in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so"
#9  Foam::expressionField::write() in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so"
#10  Foam::expressionField::expressionField(Foam::word const&, Foam::objectRegistry const&, Foam::dictionary const&, bool) in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so"
#11  Foam::OutputFilterFunctionObject<Foam::expressionField>::allocateFilter() in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so"
#12  Foam::OutputFilterFunctionObject<Foam::expressionField>::start() in "/home/hs/OpenFOAM/hs-2.2.1/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so"
#13  Foam::functionObjectList::read() in "/opt/OpenFOAM-2.2.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#14  Foam::Time::run() const in "/opt/OpenFOAM-2.2.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#15  Foam::Time::loop() in "/opt/OpenFOAM-2.2.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#16  Foam::simpleControl::loop() in "/opt/OpenFOAM-2.2.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#17
#18  __libc_start_main in "/lib64/libc.so.6"
#19
 at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116
Am I doing something wrong or is there any other way to evaluate these source terms? I could probably still write an expression and recalculate Ru since Sh and Rp are available but to me that seems to be an unneccessary workaround.
Thanks a lot for any help
Hannes
hanness is offline   Reply With Quote
Old   August 7, 2013, 12:35
Assistant Moderator
Bernhard Gschaider
Originally Posted by hanness View Post
libs (
functions
    radiation_Rp
        autowrite       true;
    radiation_Ru
        autowrite       true;
    radiation_radSource
        autowrite       true;
Starting time loop
  radiation_Rp:
  radiation_Ru:
 type:volScalarField
FOAM aborting
#17
#19
Hannes
Should work and I'm a bit amazed about the failure. If you could a provide a small case to reproduce the problem on http://sourceforge.net/apps/mantisbt...?page_number=1 I'll look into it
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 11, 2014, 10:32
Alex
zfaraday will become famous soon enough
Hello Bernhard and Hannes!
I was looking for some info about the fvDOM method when I unintendedly got to this thread. I didn't know this functionality of swak4foam, since I don't usually use it although I have it installed. Can you, please, explain me a little how it works and what are the outputs? I have copypasted the piece of code Hannes posted and I have the same problem with the Ru part. Where can I find the documentation about this functionality (and all the other ones)?
Thanks in advance.
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   November 11, 2014, 11:48
Assistant Moderator
Bernhard Gschaider
Thanks in advance.
Alex
The functions in that plugin call the functions of the radiation model. That's all. Names are similar to those of the C++-API so the best documentation is the Doxygen of the radiationModel. Documentation about the plugin-functions is going to happen if I have nothing else to do (very unlikely) or I find some funding to do it (also unlikely)
buoyantsimplefoam, radiation, swak4foam error
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
HELP PLS: Simplefoam manipulated to add diffusive mass transport...but solver stops!! 1gn0rant OpenFOAM Running, Solving & CFD 1 August 13, 2010 12:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
Solver stops abruptly without errors prabhu CFX 1 December 20, 2007 02:35
