Initialization of the temperature during the simulation |
August 6, 2013, 06:55 |
Amin
Rep Power: 13 |
Hello
I am simulating a flow past bluff body using icoFOAM. i ran the simulation for 94 sec and it was stabilized, the next step is to add the temperature in the simulation and to restart the run from the last timestep. (i added temperature in icoFoam-solver) and my question is : How can i initialize the temperature properly in last time-step file (94 s) in order to solve the problem correctly ? Thank you |
Temperature field stops changing in transient simulation | Jeffzda | OpenFOAM Running, Solving & CFD | 1 | September 25, 2013 02:19 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 07:08 |
LTCC(Low Temperature Co-fired Ceramic) substrate simulation | vineeth | Main CFD Forum | 0 | October 28, 2009 01:25 |
High temperature methane+air | Peter | FLUENT | 5 | January 26, 2009 19:04 |
need suggestion on temperature simulation | Bin Li | CFX | 4 | June 23, 2000 03:35 |
