OpenFoam Parallel running
Old   August 3, 2013, 00:26
Default OpenFoam Parallel running
Baris (Heewa)
shipman is on a distinguished road
Hi everbody,
I saw all post about the parallel running in openfoam and I thought that some of you can help to me about my case.
Truely speaking, I am new OF user and try to solve cavitating flows inside of the injector nozzle. I am using cavitatingFoam. I faced problem during the parallel running. ny pc has 24 CPU. So i set the decomposePArDict as follows to use 20 CPU;
object decomposeParDict;
numberOfSubdomains 20;
method simple;
simpleCoeffs
n ( 5 4 1 );
delta 0.001;
about decomposition there is no problem, but when i try to run the program; mpirun -np 20 cavitatingFoam -parallel
it gives following error;
~/OpenFOAM/efs-cal-2.2.1/run/470000meshes/water/Pin_0.25$ mpirun -np 20 cavitatingFoam -parallel
/opt/intel/composer_xe_2013.3.163/mpirt/bin/intel64/mpirun: 96: .: Can't open /opt/intel/composer_xe_2013.3.163/mpirt/bin/intel64/mpivars.sh
Do you have any idea how can i solve thiss problem?
Thanks in advance.
shipman is offline   Reply With Quote
Old   August 3, 2013, 05:38
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
The line tells you the problem
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   August 4, 2013, 02:45
Baris (Heewa)
Dear Linnemann, Actually i am new user, and didnt understand that line. COuld you tell me please what i should do?
Thanks in advance
Old   August 17, 2013, 11:50
Retired Super Moderator
Bruno Santos
Greetings to all!
@George: Does the file "/opt/intel/composer_xe_2013.3.163/mpirt/bin/intel64/mpivars.sh" exist?
You can check it by running:
ls -l /opt/intel/composer_xe_2013.3.163/mpirt/bin/intel64/mpivars.sh
It's possible that either the "mpirt" or the "composer xe" is incorrectly installed or that this file does not have enough permissions to be used.
Best regards,
Bruno
Large test case for running OpenFoam in parallel fhy OpenFOAM Running, Solving & CFD 23 April 6, 2019 10:55
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running sunliming OpenFOAM Bugs 21 November 22, 2013 04:38
Running in parallel Djub OpenFOAM Running, Solving & CFD 3 January 24, 2013 17:01
Running PimpleDyMFoam in parallel paul b OpenFOAM Running, Solving & CFD 8 April 20, 2011 06:21
OpenFOAM 14 stock version parallel bug msrinath80 OpenFOAM Bugs 2 May 30, 2007 15:47
