turbulent channel flow with spanwise oscillating velocity boundary condition
Old   August 5, 2013, 08:13
Question turbulent channel flow with spanwise oscillating velocity boundary condition
arnaud6 is on a distinguished road
Hello foamers,
I'm trying to validate Stokes second problem, which is a turbulent channel flow with the bottom and top walls in spanwise oscillation. To do this, I have changed the oscillatingFixedValue already implemented in the software.
I have changed from Vwall=1+Asinwt to Vwall=Asinwt in the 0/U directory for the bottom and top walls. My results are not so good and I am currently wondering whether I should change the 0/k file ?
As the turbulent kinetic energy k is only linked to the fluctuations, k=1/2*(u'2 +v'2+w'2), do the wall movements keep k=0 on the walls? Or does it introduce a sinusoidal value of k?
Thanks for your help !
arnaud6 is offline   Reply With Quote
Old   August 5, 2013, 15:18
I precise that I am using LES with OneEqEddy (like in the channel395 tutorial case) and working at a Retau=200.
boundary condition, channel flow, oscillatingfixedvalue, spanwise, value of k
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Rotating wall velocity boundary condition for axisymmetric flow problem diwakaranant SU2 1 March 24, 2013 00:45
Mass flow rate boundary condition for continuity equation for oscillating flow p07ip705 Main CFD Forum 0 February 28, 2013 02:33
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
