Moving mesh, field recalulation for ablation
Old   August 3, 2013, 19:03
Default Moving mesh, field recalulation for ablation
Nathanael3 is on a distinguished road
I am trynig to set up a moving mesh following a chemical reacting front.
I want to move the boundary in order to follow the reacting front and so ablate the domain.
I got familiarized with mesh deformation (point displacelement, boundary velocity, ...).
My problem is the calculation of the cell values after the mesh moved. For example : if there if 1500 kg/m3 of coal in a cell, when its volume has been halfed the new value is 3000 kg/m3. I would like this value to still be 1500 kg/m3 after the mesh moved.
Do I have to turn on or off something in a motion solver ? Any idea ?
Best regard,
Nathanael.
Nathanael3 is offline   Reply With Quote
moving mesh
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] 2D AMI Moving Mesh with sHM; How hard can this be? ADGlassby OpenFOAM Meshing & Mesh Conversion 18 June 18, 2013 07:07
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 09:59
