big difference between clockTime and executionTime |
February 19, 2014, 08:20 |
#21 |
Rep Power: 16 |
Hi Bruno,
I managed to get OpenFOAM running on the cluster for 2 nodes using the method that you proposed. This time, I don't copy the case folder to the cluster node temporary folder and run openfoam application by using the "-case" statement. PBS job script that I use: Code:
#!/bin/bash # # --- SET THE PBS DIRECTIVES #PBS -l walltime=2:00:00 #PBS -l select=2:ncpus=16:mpiprocs=16:mem=4000mb #PBS -e ehk112_err #PBS -o ehk112_out #PBS -m ae #PBS -M erwanhafizi@hotmail.com #PBS -V echo "=============================================" echo "FOLDER LOCATION AND NAME" echo "=============================================" CASEFOLDER="damBreak32" CASELOCATION="$WORK/CASEFOLDER/" echo $CASEFOLDER echo $CASELOCATION echo "=============================================" echo "SOURCING SYSTEM BASHRC" echo "=============================================" . $HOME/.bash_profile echo "=============================================" echo "SOURCING OPENFOAM 2.2.x BASHRC" echo "=============================================" . /home/ehk112/OpenFOAM/OpenFOAM-2.2.x/etc/bashrc echo "=============================================" echo "CD TO CASE FOLDER" echo "=============================================" cd $CASELOCATION/$CASEFOLDER echo "=============================================" echo "RUNNING OPENFOAM BATCH SCRIPT" echo "=============================================" ./Allrun Code:
#!/bin/bash # =============================== # PREPARE CASES # =============================== rm log.* cp -rf 0/backup/* 0/ # =============================== # MESHING # =============================== blockMesh -case /work/ehk112/CASEFOLDER/damBreak32 > log.blockMesh 2>&1 # =============================== # SET FIELD # =============================== setFields -case /work/ehk112/CASEFOLDER/damBreak32 > log.setField 2>&1 # =============================== # DECOMPOSE DOMAIN # =============================== decomposePar -case /work/ehk112/CASEFOLDER/damBreak32 > log.decomposePar 2>&1 # =============================== # RENUMBER MESH # =============================== renumberMesh -overwrite -case /work/ehk112/CASEFOLDER/damBreak32 > log.renumberMesh 2>&1 # =============================== # RUN APPLICATION # =============================== mpirun -hostfile $PBS_NODEFILE -np 32 interFoam -parallel -case /work/ehk112/CASEFOLDER/damBreak32 > log.interFoam 2>&1 Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-0ee7dc546f1b Exec : interFoam -parallel -case /work/ehk112/CASEFOLDER/damBreak32 Date : Feb 19 2014 Time : 10:31:39 Host : "cx1-9-17-2.cx1.hpc.ic.ac.uk" PID : 28546 Case : /work/ehk112/CASEFOLDER/damBreak32 nProcs : 32 Slaves : 31 ( "cx1-9-17-2.cx1.hpc.ic.ac.uk.28547" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28548" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28549" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28550" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28551" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28552" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28553" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28554" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28555" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28556" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28557" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28558" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28559" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28560" "cx1-9-17-2.cx1.hpc.ic.ac.uk.28561" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30201" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30202" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30203" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30204" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30205" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30206" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30207" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30208" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30209" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30210" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30211" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30212" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30213" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30214" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30215" "cx1-9-17-4.cx1.hpc.ic.ac.uk.30216" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading g Calculating field g.h No finite volume options present time step continuity errors : sum local = 0, global = 0, cumulative = 0 DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 deltaT = 0.00119048 Time = 0.00119048 MULES: Solving for alpha1 Phase-1 volume fraction = 0.130194 Min(alpha1) = 0 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.130194 Min(alpha1) = 0 Max(alpha1) = 1 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0039953, No Iterations 1 time step continuity errors : sum local = 0.00110536, global = 0, cumulative = 0 DICPCG: Solving for p_rgh, Initial residual = 0.00192022, Final residual = 6.91678e-05, No Iterations 17 time step continuity errors : sum local = 3.98241e-05, global = -9.70428e-06, cumulative = -9.70428e-06 DICPCG: Solving for p_rgh, Initial residual = 5.5586e-05, Final residual = 9.36665e-08, No Iterations 62 time step continuity errors : sum local = 6.72902e-08, global = 7.69607e-09, cumulative = -9.69659e-06 ExecutionTime = 0.18 s ClockTime = 0 s Thank you so much Bruno. Kind regards, katakgoreng |
February 15, 2019, 04:05 |
#22 |
Saleh Abuhanieh
Rep Power: 9 |
I faced similar problem while running foam 4.0 on a cluster. I was using the openmpi which comes with foam. Whatever the number of the required processors, foam was assigning all of them to the same node although SLURM is booking the required number of nodes! problem solved when I changed the openmpi to the system one. Hope that may help somebody. Saleh |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Difference between executionTime and clockTime | jml | OpenFOAM Running, Solving & CFD | 1 | December 10, 2008 08:58 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
