IcoFoam with variable time step not writing every writeInterval
Old   July 29, 2013, 20:34
Default IcoFoam with variable time step not writing every writeInterval
wildfire230 is on a distinguished road
I've modified icoFoam.C and run wmake to allow icoFoam to use the variable time step. However, when I run it, icoFoam does not write an file every writeInterval. It seems random whether it will write a certain writeInterval or not.
For example, if my endTime = 10 s, and my writeInterval = 0.5 s, icoFoam might only write 0.5, 2.5, 3,3.5, 5, 7.5, 9.
Has anyone had this problem? My icoFoam.C is given below:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Copyright (C) 2011-2012 OpenFOAM Foundation
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
Application
icoFoam
Description
Transient solver for incompressible, laminar flow of Newtonian fluids.
#include "fvCFD.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
#include "initContinuityErrs.H"
#include "readTimeControls.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.loop())
#include "readPISOControls.H"
#include "CourantNo.H"
#include "setDeltaT.H"
runTime++;
Info<< "Time = " << runTime.timeName() << nl << endl;
// #include "readPISOControls.H"
// #include "CourantNo.H"
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
solve(UEqn == -fvc::grad(p));
// --- PISO loop
for (int corr=0; corr<nCorr; corr++)
volScalarField rAU(1.0/UEqn.A());
volVectorField HbyA("HbyA", U);
HbyA = rAU*UEqn.H();
surfaceScalarField phiHbyA
"phiHbyA",
(fvc::interpolate(HbyA) & mesh.Sf())
+ fvc::ddtPhiCorr(rAU, U, phi)
adjustPhi(phiHbyA, U, p);
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
pEqn.setReference(pRefCell, pRefValue);
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi = phiHbyA - pEqn.flux();
#include "continuityErrs.H"
U = HbyA - rAU*fvc::grad(p);
U.correctBoundaryConditions();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
wildfire230 is offline   Reply With Quote
Old   July 31, 2013, 18:49
Ashvin Chaudhari
ashvinc9 is on a distinguished road
I had a same problem for pisoFoam, and I guess this is because of "while (runTime.loop())". I then modified my solver as it is in e.g. pimpleFoam. In your case, the icoFoam.C file should look like:
   \\    /   O peration     |
     \\/     M anipulation  |
License
    for more details.
Application
    icoFoam
Description
#include "fvCFD.H"
  //   #include "readTimeControls.H"
    while (runTime.run())
        runTime++;
        fvVectorMatrix UEqn
            fvm::ddt(U)
          + fvm::div(phi, U)
        // --- PISO loop
                "phiHbyA",
                fvScalarMatrix pEqn
                pEqn.solve();
        runTime.write();
            << nl << endl;
    return 0;
just copy above code, this should work for you !
-Ashvin
ashvinc9 is offline   Reply With Quote
Previous time step variable to be used in UDF CFD-user Fluent UDF and Scheme Programming 18 June 23, 2022 02:17
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
