LES: Turbulent Channel Flow without initial solution (BC)
Like Tree18Likes
Old   September 6, 2013, 06:10
Danesh S
DaSh is on a distinguished road
To be closed. Thanks.
DaSh is offline   Reply With Quote
Old   February 8, 2015, 17:09
Ali Shamooni
Alish1984 is on a distinguished road
Originally Posted by Lieven View Post
Hi Danesh,
Were you already using the channelFoam solver? Cause based on the fact that you mentioned you were using RAS profiles I assumed you were not (channelFoam accepts only LES turbulence models). If you are, you are correct the pressure gradient should be imposed already based on comparing the actual mean flow rate with the requested mean flow rate (from the transportProperties).
But if you are using pisoFoam, you need to include tis pressure gradient yourself in the equation. You can follow either this approach, so imposing a flow rate, or you can directly set 'gradP' as a fixed value.
Cheers,
Lieven
Dear Lieven
Is it possible to solve a nozzle with the concept used in the channelFoam?
I mean I guess cyclicBC & gradpPlus used in the solver is the combination that generates turbulence in your field when using LES. If I am wrong tell me.
When the area in the inlent and outlet are not the same, then u cant use cyclic. without cyclicBC and using channelFoam it is likely to end up in a Poiseuille flow result (by using pisoFoam),
Then how can u solve this problem. I mean simulation of flow in a nozzle using LES.
Regards
Ali
Alish1984 is offline   Reply With Quote
channel flow, convergence, initial condition, les
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 22:51
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
pisoFoam - unstable pressure residual Industrial_CFD OpenFOAM Running, Solving & CFD 21 February 24, 2013 16:39
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
