Boundary condition in outdoor flow
Old   July 19, 2013, 06:37
Default Boundary condition in outdoor flow
zako
bigzakk is on a distinguished road
Hi Guys,
I would like to set up a simulation with no wind flow. which boundary condition is more appropriate. any help is most welcome
Regards
bigzakk is offline   Reply With Quote
Old   July 21, 2013, 21:34
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
What do you mean by no wind flow?
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   July 22, 2013, 04:22
zako
Hi Mojtaba.a,
Thanks for your reply. I have a flow field with an inlet and outlet flow But I am interested in investgating a situation in which the inlet velocity is zero. I was wondering what are the boundary condition appropriate for this kind of simulation. I am using simpleFoam with a k and omega tubulence model.
kind regards
Old   July 22, 2013, 09:10
Mojtaba.a's Avatar
Originally Posted by bigzakk View Post
Hi Mojtaba.a,
kind regards
If you have zero inlet velocity, so what is going to move your fluid flow?
looking at your selected solver, you are not going to solve a natural convection problem either.
So what exactly are you going to model?
Old   July 22, 2013, 09:21
zako
I am trying to model buoyancy.... I was hoping that only buoyancy will move the flow
Old   July 22, 2013, 09:36
Artem Shaklein
ARTem is on a distinguished road
Then use buoyantSimple(Pimple)Foam. A tutorial with room with hot floor, cold ceiling and adiabatic walls can be found in tutorials/heatTransfer/buoyantSimple(Pimple)Foam/hotRoom
ARTem is offline   Reply With Quote
Old   July 22, 2013, 09:47
zako
yes thats what I am using now. The question is how will I model the walls in case of atmospheric buoyant flow ?
Old   July 22, 2013, 10:17
Artem Shaklein
You want to simulate a case with a boundary with unknown in advance flow direction (in or out) and parameters?
I just can't see the problem in describing solid walls (the same way as in non-buoyant flows).
Old   July 22, 2013, 10:19
Mojtaba.a's Avatar
If you are going to model a building and simulate the flow around it, just model the building and put it within a big volume which will represent the air.
you can you use ABLInletVelocity for air inlet, and symmetry on lateral and top planes of the volume.
Use appropriate wallFunction on the building, and start the simulation.
or of you are not going to use inlet, just heat up the building walls and see what happens due to buoyancy.
I hope it helps a bit,
Mojtaba
Old   July 22, 2013, 10:23
zako
Thanks a lot guys
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
