cannot find file ...dsmcSigmaTcRMax at line 0
Old   July 17, 2013, 03:58
Default cannot find file ...dsmcSigmaTcRMax at line 0
Carl
jiaoxiaolei is on a distinguished road
dear foamers, when I use dsmcfoam,there is a problem,can not find file....just below,so what should I do to solve it??
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.0-5be49240882f
Exec : dsmcFoam
Date : Jul 17 2013
Time : 14:52:24
Host : "ubuntu"
PID : 3396
Case : /opt/openfoam220/tutorials/discreteMethods/dsmcFoam/test/shilia
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Constructing dsmcCloud
--> FOAM FATAL IO ERROR:
cannot find file
file: /opt/openfoam220/tutorials/discreteMethods/dsmcFoam/test/shilia/0/dsmcSigmaTcRMax at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
jiaoxiaolei is offline   Reply With Quote
Old   July 17, 2013, 05:06
Bernhard
Bernhard is on a distinguished road
OpenFOAM error-messages are often very clear. What do you think is wrong here? Hint: see your title. So, what can you do to fix it? Right, supply the right file. Did you run dsmcInitialise as the tutorials suggest?
Bernhard is offline   Reply With Quote
Old   July 18, 2013, 03:21
Carl
Hi Bernhard,thanks for your suggestion,I found my flow field is too large, so, there are too many dsmcparticles,when I change numberdensities,it works fine ! this problem did not appear any more,why??
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
