potentialFoam error
Old   July 8, 2013, 09:21
Default potentialFoam error
achyutan is on a distinguished road
I need to run unsteady incompressible flow in pisoFoam. Since my soln was blowing up, I wanted to start from steady state soln and i turned towards potentialFoam.
I get floating point exception error when running potentialFoam.
[sudarsan@nebula run]$ potentialFoam
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : potentialFoam
Date   : Jul 09 2013
Time   : 00:32:24
Host   : "nebula.iitm"
PID    : 27873
Case   : /home/sudarsan/home/my_cases/stat_cylinder/run
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Calculating potential flow
DICPCG:  Solving for p, Initial residual = 1, Final residual = 6.12067e-07, No Iterations 64
DICPCG:  Solving for p, Initial residual = 0.18173, Final residual = 7.69672e-07, No Iterations 56
DICPCG:  Solving for p, Initial residual = 0.103597, Final residual = 9.29651e-07, No Iterations 53
DICPCG:  Solving for p, Initial residual = 0.068186, Final residual = 9.67935e-07, No Iterations 55
continuity error = 7.12386e-06
#0  Foam::error::printStack(Foam::Ostream&) in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 at sigaction.c:0
#3  Foam::inv(Foam::Field<Foam::SymmTensor<double> >&, Foam::UList<Foam::SymmTensor<double> > const&) in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 in "/root/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/potentialFoam"
#8  __libc_start_main in "/lib64/libc.so.6"
Floating point exception
my mesh has got non-orthogonality issues. I am attaching the case here.
can somebody help me ?
achyutan
achyutan is offline   Reply With Quote
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
user defined function cfduser CFX 0 April 29, 2006 11:58
