waveDyMFoam stability issue
Old   July 3, 2013, 01:04
Default waveDyMFoam stability issue
chris goody
goodster is on a distinguished road
aloha everyone,
this is kind of a 'hail mary' pass, but after 50+ iterations of trying to tweak this case, i'm starting to get a little frustrated at my own lack of skill and if anyone has the time and/or inclination to check it out, i would be much obliged.
This is the model case:
> loosely based on the floating object tutorial, i modified it to be a floating cylinder with sHM
> I made the modifications incrementally, (1) first the tutorial, (2) then the tutorial with waves, (3) then the tutorial with a sHM cylinder in lieu of the floating object, (4) and finally the waves with the sHM object. All have worked except the last case.
> The case fails because the pressure will not converge, and when i look at the body force output, it appears that all is well until about 120 seconds, where the force/pressure begins to fluctuate wildly right before blowing up.
> CheckMesh reported that the mesh was OK, but i have a gut feeling the mesh is at least partly responsible...
> it also seems like the issue brought up here may also be a part of the problem:
http://www.cfd-online.com/Forums/ope...ject-case.html
> and lastly, I've become obsessed with making this work, and i think my sanity may have blown up along with the model, at the 43 year time step.
anyone who's interested can check the model setup out by downloading the archive from here:
https://www.dropbox.com/s/ahkeblkyj3...sLoRes.org.zip
sorry in advance for groveling for help, any constructive comments/advice/opinions are very much appreciated.
also wish to thank Mr. Niels Jacobsen for this very useful waves2foam tool.
goodster is offline   Reply With Quote
Old   July 7, 2013, 21:10
chris goody
I'm desperately looking for a sanity check; can anyone out there suggest or comment on appropriate schemes and tolerances to use for the velocity, pressure and displacement solutions for the above waveDyMfoam/interdymfoam? The case is based on the floatingObject tutorial but with a cylinder gridded by SnappyHexMesh and my fvSchemes and fvSolution files are provided below.....
Mahalo,
Chris
fvschemes
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rho*phi,U)  Gauss vanLeerV;
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha;
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    cellDisplacement
        solver                  GAMG;
        tolerance               1e-07;
        relTol                  0;
        smoother                GaussSeidel;
        cacheAgglomeration      true;
        nCellsInCoarsestLevel   10;
        agglomerator            faceAreaPair;
        mergeLevels             1;
    pcorr                               // linear equation system solver for p
        solver          GAMG;           // very efficient multigrid solver
        tolerance       1e-13;          // solver finishes if either absolute
        relTol          0;              // tolerance is reached or the relative
                                        // tolerance here
        minIter         3;              // a minimum number of iterations
        maxIter         200;            // limitation of iterions number
        smoother        GaussSeidel;    // DIC - setting for GAMG
        nPreSweeps      1;              // 1 for p, set to 0 for all other!
        nPostSweeps     2;              // 2 is fine
        nFinestSweeps   2;              // 2 is fine
        scaleCorrection true;           // true is fine
        directSolveCoarsestLevel false; // false is fine
        cacheAgglomeration on;          // on is fine; set to off, if dynamic
                                        // mesh refinement is used!
        nCellsInCoarsestLevel 500;      // 500 is fine,
                                        // otherwise sqrt(number of cells)
        agglomerator    faceAreaPair;   // faceAreaPair is fine
        mergeLevels     1;              // 1 is fine
    p_rgh
                                                    // tolerance here
    p_rghFinal
        $p_rgh;
        tolerance       1e-15;
        relTol          0;
    U                                   // linear equation system solver for U
        solver          smoothSolver;   // solver type
        smoother        GaussSeidel;    // smoother type
        tolerance       1e-10;          // solver finishes if either absolute
                                        // tolerance here
        nSweeps         1;              // setting for smoothSolver
        maxIter         200;            // limitation of iterations number
    UFinal                              // linear equation system solver for U
        tolerance       1e-07;          // solver finishes if either absolute
                                        // tolerance here
    k
        tolerance        1e-07;
        relTol           0;
        nSweeps          1;
    kFinal
        tolerance        1e-07;
        relTol           0;
        nSweeps          1;
    epsilon
        tolerance        1e-07;
        relTol           0;
        nSweeps          1;
    epsilonFinal
        tolerance        1e-7;
        relTol           0;
        nSweeps          1;
relaxationFactors
    p               0.3;                // 0.3 is stable, decrease for bad mesh
    U               0.7;                // 0.7 is stable, decrease for bad mesh
    k               0.5;
    epsilon         0.5;
PIMPLE
    //pRefCell                  0;
    //pRefValue                 0;
    turbOnFinalIterOnly         yes;
    momentumPredictor           yes;
    nCorrectors                 4;
    nOuterCorrectors            2;
    nNonOrthogonalCorrectors    1;
    nAlphaCorr                  1;
    nAlphaSubCycles             4;
    cAlpha                      1;
Old   July 9, 2013, 18:02
kilroy's Avatar
kilroy is on a distinguished road
Hello Chris,
I am having exactly the same issues with waveDyMFoam (interDyMFoam). You cant even run a bobbing cork in 1D with this solver since the mesh motion,VOF and 6DOF solvers are weakly coupled. I was trying to model a speed boat traveling through the waves but it did not work. My simulations were blowing up because of pressure instabilities.
My advice to you is to stop working on it. You are just wasting your time. I don't think you will ever get it working. Either you can try to check solvers working on old versions (shipFoam etc.) or you can try to modify waveDyMFoam to create your own solver.
Please let me know of your progress
Good luck
Kilroy
kilroy is offline   Reply With Quote
Old   July 12, 2013, 23:30
chris goody
Thanks for the advice kilroy. I wish i could stop wasting my time, but i think i may be too stubborn.
anyway, do you, or anyone else for that matter, have any idea why the simulation actually works with waveDyMFoam when using only blockmesh (i.e., using cellset and subset mesh to define the body) and then fails when using snappyHexMesh?
Maybe having to do with cell orthogonality?? THat's the only difference i can think of...
mahalo,
chris
Old   July 15, 2013, 11:16
kilroy's Avatar
Chris,
I think it is definitely because of the mesh quality. Mesh created with "snappyHexMesh" is not good enough for moving mesh. And I don't think it will be working just with "blockMesh" etiher. If yours worked with just "blockMesh", I think that may just be luck. If you try to change the size of your object, I am sure your simulation will crash immediately.
If you have a chance can you increase the size of your floating object (double the dimensions) and let me now if it works or not?
Thanks
Kilroy
Old   November 17, 2013, 14:45
maryam morta
mary mor is on a distinguished road
Hi Kilroy and Chris,
I'm trying to simulate almost the same problem, a floating object across waves. As I've seen in several posts that people mention the bugs and crashing withing the floating object tutorial I just wonder if you have solved the problem or not.
The shipfoam solver that Kilroy mentioned is another choice but I didn't know how to find the latest version of it.Also can it be compatible with wave2Foam or not?
If you can share anything please share it with me. I'm in desprate need in doing this problem
Best regards
Maryam
mary mor is offline   Reply With Quote
Old   September 23, 2018, 05:40
Default waveDyMFoam problem on v1606
金恒
jinheng is on a distinguished road
dear foamer,
when I run a case with floatingbody,I faced this error. And the same case worked on v3.0.1. The detail error are list here.
Thanks for anyone's help or advices.
--> FOAM FATAL ERROR:
object of type N4Foam12sixDoFSolverE is not allocated
From function T* Foam::autoPtr<T>:perator->() [with T = Foam::sixDoFSolver]
in file /home/jd2018/OpenFOAM/OpenFOAM-v1606+/src/OpenFOAM/lnInclude/autoPtrI.H at line 176.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::sixDoFRigidBodyMotion::update(bool, Foam::Vector<double> const&, Foam::Vector<double> const&, double, double) at ??:?
#3 Foam::sixDoFRigidBodyDisplacementPointPatchVectorF ield::updateCoeffs() at ??:?
#4 Foam::displacementLaplacianFvMotionSolver::solve() at ??:?
#5 Foam::motionSolver::newPoints() at ??:?
#6 Foam::dynamicMotionSolverFvMesh::update() at ??:?
#7 main at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Aborted (core dumped)
jinheng is offline   Reply With Quote
openfoam 2.0.1, wavedymfoam, waves2foam
Stability Issue with interDyMFoam / floatingObject tutorial ccmccomb OpenFOAM Running, Solving & CFD 4 April 27, 2023 05:13
when I use multi block the condition of stability can not be fulfilled mostafa_khan FLOW-3D 2 April 19, 2012 13:17
Stability issue while running buoyantFoam fandall OpenFOAM Running, Solving & CFD 13 May 9, 2011 12:36
stability and number of processors ?? sersunzo OpenFOAM Running, Solving & CFD 0 June 9, 2009 12:45
Solving linear stability eq. K S Chang Main CFD Forum 3 January 19, 2004 17:01
