June 25, 2013, 05:56 |
running utility command every timeStep
Thomas Reviol
Rep Power: 15 |
Dear Foamers,
I am running an unsteady calculation and I want to calculate the mean Stanton-Number with the mean values of some timeSteps. My Problem is, I have to calculate the mean wallHeatFlux, or the wallHeatFlux for every timeStep. And I dont' know how to realise an automatic procedure to do this. Is there any posibility to run the utility "wallHeatFlux" for every timeStep, e.g. via a function in the controlDict? Or does anyone know alternatives to calculate the mean wallHeatFlux? Regards Thomas |
June 25, 2013, 09:21 |
Thomas Reviol
Rep Power: 15 |
Hello Foamers,
I found the function "systemCall" (see $FOAM_SRC/postProcessing/functionObjects/systemCall). With this function, it is possible to run the utility "wallHeatFlux" for each TimeStep. With this function, the effort to estimate the stanton-number is very high. Does anyone know a better method? Regards Thomas |
how to run the propeller Tutrial | immortality | OpenFOAM Running, Solving & CFD | 10 | February 22, 2014 09:33 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
running without rsh between nodes | hattonps | OpenFOAM | 10 | March 22, 2010 15:02 |
What do you CFD guys do during a long simulation running? | bearcat | Main CFD Forum | 5 | July 23, 2009 08:08 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
