June 20, 2013, 21:31 |
Problem with pressure boundary conditions
Saša G.
Greatings to everyone.
I hope someone can help me with a problem. I have been learning to use openFoam for past couple of weeks so I could use it for a bit of analyzing of Smagorinsky model, which is topic of my thesis. I have run already a couple simple tests like lid driven cavity flow, flow over an obstacle and so on, mainly simple 2D test problems. My mentor sugested i try to model a blood flow through bifurcation with an aneurysm. So i have basicly three pipes, of different diameters, one inlet, two outlets, that are connected at a junction and one of the pipes has a widening. The fluid is assumed to be incompressible Newtonian fluid. At first try I have setup the case in a way that i prescribe time-varying Pouiselle velocity profile on inlet, fixedValue pressure and zeroGradient velocity on outlet. So far so good, I solved the case with IcoFoam and with pimpleFoam with Smagorinsky model for comparisson. Then my mentor suggested I try to prescribe time-varying pressure on inlet and fixedValue pressure on outlets. Thats where the trouble begins. Again i try to solve it with icoFoam first. I used the folowing initial-B.C.: Code:
0/p // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type uniformFixedValue; uniformValue tableFile; tableFileCoeffs { fileName "pressuredrop.txt"; outOfBounds repeat; } } outlet1 { type fixedValue; value uniform 0; } outlet2 { type fixedValue; value uniform 0; } walls { type zeroGradient; } UpDown { type empty; } } // ************************************************************************* // Code:
0/U // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet1 { type zeroGradient; } outlet2 { type zeroGradient; } walls { type fixedValue; value uniform (0 0 0); } UpDown { type empty; } } // ************************************************************************* // When i change inlet in 0/U to: Code:
inlet { type pressureInletUniformVelocity; value uniform (0 0 0); } I would think it's icoFoam thats causing the trouble but i'm not sure because very similar case with pulsating Pouiselle profile works like a charm. I would think that it's the mesh but mesh looks ok and pasess checkMesh with reasonable results, screenshot is attached below So i'm thinking it's boundary conditions, since the whole trouble starts at inlet. I have tried using different B.C for velocity on outlet too, ( InletOutlet ) but to no avail. I have also tried to use different, nCorrection, nNonOrthCorr and so on but nothing helped. Sorry if it's a stupid question, I'm very new to OF Thanks in advance for any advice |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
stagnation pressure boundary problem | mbgnfrx2 | STAR-CD | 2 | November 25, 2012 23:55 |
Problems with boundary conditions - velocity and pressure not zero | M_Flodin | FLUENT | 0 | April 1, 2011 09:32 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
