where are the compiled executables?
Old   June 20, 2013, 17:58
Question where are the compiled executables?
Y
peteryuan is on a distinguished road
hi guys,
i learned that one can compile solver in a applications/solvers folder, with wmake. and then use the compiled solvers in cases.
my question is, i was looking for the compiled exe file like icoFoam, but i only find the source code in .C.
but in the cavity tutorial i already used icofoam. could someone tell me how this work?
my second question, i did not find in bashrc file something about icoFoam, so how does this work, that when i type icoFoam, this solver is executed?
yo see i m a beginner, thanks for help.
peter
peteryuan is offline   Reply With Quote
Old   June 21, 2013, 03:08
Nima Samkhaniani
nimasam is on a distinguished road
Originally Posted by peteryuan View Post
hi guys,
executable file are placed in following addresse:
/opt/openfoam220/platforms/linuxGccDPOpt/bin
ofcourse i assumed you installed your OpenFOAM on opt folder
peter
as you source your bashrc file during installation, you tell linux to read OpenFOAM bashrc which contains address of other folder paths, so it look up for example above address and returns your executable file
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 21, 2013, 04:44
Markus Rehm
markusrehm is on a distinguished road
Hi Peter,
the .bashrc is a script which sets your environment variables where your system looks for the executables. To see where the icoFoam executable hides you can use the command
which icoFoam
Also the last line of a successful wmake-compilation gives you the full path to the produced executable.
Consider reading more about shell programming or read a bash tutorial.
Markus
markusrehm is offline   Reply With Quote
Old   June 21, 2013, 05:13
Y
Thanks, I got it.
compile
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 08:17
Using compiled UDF:s in different Fluent versions S H FLUENT 1 September 12, 2007 04:40
how to compile compiled UDF? AVINASH FLUENT 3 January 19, 2007 05:04
.F compiled on Winnt works, but on AIX doesn't Daiga CFX 11 May 9, 2006 08:44
DEFINE_CG_MOTION Interpreted or Compiled? Aussie Shane FLUENT 0 April 20, 2006 05:50
