icoFoam - Floating point exception (core dumped) |
July 18, 2013, 06:44 |
#21 |
Amin
Rep Power: 13 |
i do not really want to a final steady-state solution, that is why i am trying a transient solver .
but nimasam suggested, that i can use simpleFoam for for laminar flow, that is why i try to add the temperature in the simpleFoam solver. |
August 4, 2013, 12:49 |
#22 |
Gabriel Boucher
Rep Power: 13 |
Hello everyone, I also have a problem with my courant number.
In order to practice with OpenFOAM (since I'm a beginner), I tried to create a simple nozzle with blockMesh. To run the case, I use the elbow simulation with icoFoam. I changed the meshing to use the one I created and run blockMesh. but when I run the simulation, I get courant number of the magintue e289 on the very first step... I tried a coarse meshing, but nothing changed, I tried really small time step, still nothing and now I don't know what to do . Here is my meshing: Code:
convertToMeters 0.1; vertices ( (-25 0 0.5) //0 (0 -10 0.5) //1 (0 10 0.5) //2 (-25 5 0.5) //3 (-25 0 -0.5) //4 (0 -10 -0.5) //5 (0 10 -0.5) //6 (-25 5 -0.5) //7 ); blocks ( hex (0 1 2 3 4 5 6 7) (25 25 1) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 3 7 4) ); } outlet { type patch; faces ( (1 2 6 5) ); } upperWall { type wall; faces ( (3 2 6 7) ); } lowerWall { type wall; faces ( (0 1 5 4) ); } frontAndBack { type empty; faces ( (0 1 2 3) (4 5 6 7) ); } ); mergePatchPairs ( ); Code:
application icoFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 0.1; deltaT 0.001; writeControl timeStep; writeInterval 20; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Any help would be appreciated. I try to learn OpenFoam by modifying the tutorial and this is my first (pathetic) attempt. Thanks |
August 4, 2013, 13:04 |
#23 |
Gabriel Boucher
Rep Power: 13 |
Oh nevermind, I found my error using checkMesh . My mesh orientation was not good.
April 16, 2016, 06:58 |
Floating point exception(core dumped)
#24 |
sagar
Hello Foamers,
I am new to openfoam.I have created my own solver adding temperature equation (only advection-diffusion with velocity) to the icoFoam solver. to be specific ,code is solve ( fvm::div(phi,T) - fvm::laplacian(DT,T) ); I am getting this error Courant Number mean: 0.0248669 max: 2.20364 smoothSolver: Solving for Ux, Initial residual = 0.202777, Final residual = 1.21499e+270, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.351417, Final residual = 8.3534e+269, No Iterations 1000 DILUPBiCG: Solving for T, Initial residual = 0.00762719, Final residual = 8.13923e-06, No Iterations 23 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const at ??:? #6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #10 ? at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? at ??:? Floating point exception (core dumped) After some debugging I fund out that lowering value of nu to 0.01 I am getting the output but as I lower the values to 0.001 it starts giving this output.I want to simulate it with nu=1e^-6 .What is wrong with this?I am attaching the files of the fvsolution,geometry etc. |
April 19, 2016, 11:17 |
same probleme with turbulence model
#25 |
Mehdi
Rep Power: 10 |
helo everyone i have the same probleme, i would like to simulate an airflow around an airfoil i used rhosimplefoam like a solver and when i'm compiling its apear this message:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.1-d8a290b55d28 Exec : rhoSimpleFoam Date : Apr 19 2016 Time : 15:10:30 Host : "mehdi-HP-250-G4-Notebook-PC" PID : 7408 Case : /home/mehdi/OpenFOAM/mehdi-3.0.1/run/airfoil/airfoil_rhoSimpleFoam nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.0001 field e tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; } #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/home/mehdi/OpenFOAM/OpenFOAM-3.0.1/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam:perator/(Foam::tmp<Foam::Field<double> > const&, Foam::tmp<Foam::Field<double> > const&) at ??:? #5 Foam::fluidThermo::nu(int) const at ??:? #6 Foam::TurbulenceModel<Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::compressibleTurbulenceModel, Foam::fluidThermo>::nu(int) const at ??:? #7 Foam::nutkWallFunctionFvPatchScalarField::calcNut( ) const at ??:? #8 Foam::nutWallFunctionFvPatchScalarField::updateCoe ffs() at ??:? #9 Foam::fvPatchField<double>::evaluate(Foam::UPstrea m::commsTypes) at ??:? #10 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at ??:? #11 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::correctNut() at ??:? #12 Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Fo am::ThermalDiffusivity<Foam::CompressibleTurbulenc eModel<Foam::fluidThermo> > > >::kEpsilon(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) at ??:? #13 Foam::RASModel<Foam::EddyDiffusivity<Foam::Thermal Diffusivity<Foam::CompressibleTurbulenceModel<Foam ::fluidThermo> > > >::adddictionaryConstructorToTable<Foam::RASModels ::kEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiff usivity<Foam::CompressibleTurbulenceModel<Foam::fl uidThermo> > > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:? #14 Foam::RASModel<Foam::EddyDiffusivity<Foam::Thermal Diffusivity<Foam::CompressibleTurbulenceModel<Foam ::fluidThermo> > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:? #15 ? at ??:? #16 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #17 ? at ??:? Exception en point flottant (core dumped) mehdi@mehdi-HP-250-G4-Notebook-PC:~/OpenFOAM/mehdi-3.0.1/run/airfoil/airfoil_rhoSimpleFoam$ if someone can help me please it's for my master project, thank you |
April 26, 2016, 13:03 |
#26 | |
Ehsan
Rep Power: 27 |
your courant number seems too high.may it cause the run to be unstable. reduce it to be lower than 1 by lowering time step. may it be solved.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
March 6, 2021, 05:26 |
#27 |
Madong
Rep Power: 5 |
Hello everyone,
I am a newer, and why this error occurs in OpenFoam? This is the code. Time = 1600 pseudoTime: iteration 1600 Pseudo Courant No: Min: 0.10078836 Mean: 8.467278 Max: 9.5664346 Pseudo deltaT: Min: 1.6848402e-05 Mean: 0.0054943401 Max: 0.067294106 Solving for (rho rhoU rhoE) GMRES iteration: 0 Residual: 0.0049290487 (0.003904797 0.0052534381 0.0039910031) 0.004746403 GMRES iteration: 1 Residual: 1.1723583e-06 (7.1752593e-07 7.1192873e-07 5.6116024e-07) 9.8950704e-07 ExecutionTime = 2340.76 s ExecutionStepTime = 1.68 s ClockTime = 2341 s min/max/integ(body) = -12910.768, -1033.1014, -1.6392455e+08 min/max/integ(farfield) = 0, 0, 0 wallHeatFlux wallHeatFlux write: writing field wallHeatFlux yPlus yPlus write: writing field yPlus [timothy-Super-Server:16007] *** Process received signal *** [timothy-Super-Server:16007] Signal: Floating point exception (8) [timothy-Super-Server:16007] Signal code: (-6) [timothy-Super-Server:16007] Failing at address: 0x3e900003e87 [timothy-Super-Server:16007] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x128a0)[0x1482479bc8a0] [timothy-Super-Server:16007] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0xc7)[0x1482479bc737] [timothy-Super-Server:16007] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x128a0)[0x1482479bc8a0] [timothy-Super-Server:16007] [ 3] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5U ListIdEE+0x30)[0x148248f0ce80] [timothy-Super-Server:16007] [ 4] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERKNS_3tmpINS_5FieldId EEEE+0x51)[0x148248f15e41] [timothy-Super-Server:16007] [ 5] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjec ts5yPlus7executeEv+0x31b)[0x148221d5747b] [timothy-Super-Server:16007] [ 6] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam15functionObjects11timeCont rol7executeEv+0x54)[0x148248c9b154] [timothy-Super-Server:16007] [ 7] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7execut eEv+0x108)[0x148248c8c118] [timothy-Super-Server:16007] [ 8] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0x21d)[0x148248ca5d4d] [timothy-Super-Server:16007] [ 9] hisa(+0x3cbc)[0x556972d69cbc] [timothy-Super-Server:16007] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x1482475dab97] [timothy-Super-Server:16007] [11] hisa(+0x4b4a)[0x556972d6ab4a] [timothy-Super-Server:16007] *** End of error message *** [timothy-Super-Server:16006] *** Process received signal *** [timothy-Super-Server:16006] Signal: Floating point exception (8) [timothy-Super-Server:16006] Signal code: (-6) [timothy-Super-Server:16006] Failing at address: 0x3e900003e86 [timothy-Super-Server:16006] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x128a0)[0x154a597bd8a0] [timothy-Super-Server:16006] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0xc7)[0x154a597bd737] [timothy-Super-Server:16006] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x128a0)[0x154a597bd8a0] [timothy-Super-Server:16006] [ 3] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5U ListIdEE+0x30)[0x154a5ad0de80] [timothy-Super-Server:16006] [ 4] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERKNS_3tmpINS_5FieldId EEEE+0x51)[0x154a5ad16e41] [timothy-Super-Server:16006] [ 5] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libfieldFunctionObjects.so(_ZN4Foam15functionObjec ts5yPlus7executeEv+0x31b)[0x154a33d4147b] [timothy-Super-Server:16006] [ 6] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam15functionObjects11timeCont rol7executeEv+0x54)[0x154a5aa9c154] [timothy-Super-Server:16006] [ 7] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7execut eEv+0x108)[0x154a5aa8d118] [timothy-Super-Server:16006] [ 8] /home/ubuntu/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0x21d)[0x154a5aaa6d4d] [timothy-Super-Server:16006] [ 9] hisa(+0x3cbc)[0x56239da75cbc] [timothy-Super-Server:16006] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x154a593dbb97] [timothy-Super-Server:16006] [11] hisa(+0x4b4a)[0x56239da76b4a] [timothy-Super-Server:16006] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 3 with PID 0 on node timothy-Super-Server exited on signal 8 (Floating point exception).[/COLOR] |
(core dumped), floating point exception, icofoam |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 17:23 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 04:24 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
Finished simulation doesn't start: floating point exception [Divide by zero] | MaxCFD | STAR-CCM+ | 3 | June 26, 2011 11:31 |
