omega wall function
Old   June 13, 2013, 23:48
Default omega wall function
RacMat
rvl565 is on a distinguished road
I am a little confused about the omega wall boundary condition.
I am running a turbulent flow over flat plate ( simpleFoam,komegaSST, 10m/s, 1%Tu intensity) and comparing the value of cf with a theoretical correlation.
When i use the Menter's wall boundary condition the cf is underpredicted ( about 70% error i think)
but when i use the omegawall functions value at the wall ( i run the case with the wall function for a few iterations and see what value it uses( which is a constant along the wall) and then use that particular value as 'fixedValue'), i get very good results ( <4% error)
To understand why this was happening, I looked at the omega wall function code and saw the following line:
scalar omegaVis = 6.0*nuw[faceI]/(beta1_*sqr(y[faceI]));
instead of the 60 ( as in menter's paper) there is a 6.0 in the wall function code.
Why is this so? Which one is correct?
Thanks for your help!!
rvl565 is offline   Reply With Quote
Old   June 14, 2013, 01:25
Nima Samkhaniani
nimasam is on a distinguished road
im not familiar with this model, but maybe its a bug, you can report it in bug report
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 14, 2013, 04:01
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi
Its 6 in some new versions.its an approximation assymtotic value not an exact one.
Which type of grid you use near walls?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 15, 2013, 00:11
RacMat
I am using a fine mesh near the wall... y+=1
Old   June 15, 2013, 06:17
Ehsan
you should use a very low value for k like 1e-18
for epsilon and omega test two models:both 1e-18 or both high epsilon 100000 and omega 10000 and see which is better for your case.
komegasst, menter, omega wall function
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
simpleFoam for complicated geometry, non-orthogonal mesh, omega wall function achinta OpenFOAM 2 October 25, 2013 01:58
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
Need some wall function approaches! yka8150 Main CFD Forum 0 September 22, 2009 00:08
