pimpleDyMFoam issue
Old   June 12, 2013, 17:57
Question pimpleDyMFoam issue
Giovani Diniz
giovanidiniz is on a distinguished road
Send a message via Skype™ to giovanidiniz
Guys,
I want to use OF to analyze marine propellers and, following the "propeller" tutorial, I have created my case test. I use shm to do the meshing, followed by topoSet, createBaffles and pimpleDyMFoam.
When I run createBaffles, I have a warning that some cells are set in two different zones, but I new that because the propeller hub intersects the inlet patch.
I'm using dynamicMesh to rotate the mesh as the tutorial, however, when I try to run pimpleDyMFoam, I get this log:
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.0-5be49240882f
Exec : pimpleDyMFoam
Date : Jun 12 2013
Time : 16:46:20
Host : "giovanidiniz-VirtualBox"
PID : 7004
Case : /home/giovanidiniz/Documents/OpenFoam/Prop241186
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone PropellerCell
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::solidBodyMotionFvMesh::solidBodyMotionFvMesh (Foam::IOobject const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libdynamicFvMesh.so"
#4 Foam::dynamicFvMesh::addIOobjectConstructorToTable <Foam::solidBodyMotionFvMesh>::New(Foam::IOobjec t const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libdynamicFvMesh.so"
#5 Foam::dynamicFvMesh::New(Foam::IOobject const&) in "/opt/openfoam220/platforms/linuxGccDPOpt/lib/libdynamicFvMesh.so"
in "/opt/openfoam220/platforms/linuxGccDPOpt/bin/pimpleDyMFoam"
#7 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Segmentation fault (core dumped)
]0;giovanidiniz@giovanidiniz-VirtualBox: ~/Documents/OpenFoam
Any one has any idea what might be causing this problem? I have gone over and over through the input files and I just can't find the problem.
giovanidiniz is offline   Reply With Quote
Old   July 5, 2013, 08:25
Artur's Avatar
Artur
Artur will become famous soon enough
Did you change the dynamicMeshDict in your constant directory? I had the same problem because I left it as "innerCylinderSmall" when I was building my own case based on that tutorial.
Artur is offline   Reply With Quote
pimpleDyMFoam issue for pitching foil PLD OpenFOAM Running, Solving & CFD 3 May 23, 2017 14:54
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 03:00
Error with pimpleDyMFoam samiam1000 OpenFOAM 2 June 11, 2012 07:21
Relative flux in pimpleDyMFoam Igor_2011 OpenFOAM 0 July 20, 2011 18:50
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 09:27
