How to Map Fields in openFOAM using the utility
Like Tree25Likes
Old   June 23, 2017, 06:40
Kim Le
lethu is on a distinguished road
Hello everyone,
I have been encountering problems with mapFields.
I have posted my problems here :
Mapping values with different domains, water channel
My new domain is smaller than the previous one. My new inlet and outlet are at the same position but they are cut. As I explained, the first simulation was using interFoam, the second simulation I want to carry is only using the water part.
If anyone know why mapFields does not want to map the U field, please tell me why. Thanks !
EDIT : Problem solved using reconstructPar !
lethu is offline   Reply With Quote
Old   January 13, 2018, 08:45
Default Mapping a time series
  #42
Maria
hoemmaria is on a distinguished road
Hi!
Using the information found in this thread I have successfully mapped a solution from a fine mesh over to a coarser mesh.
However, my problem is transient, and thus I would like to map several time steps to the coarser case.
An example: I want to map the time steps 0.5-1 s.
I tried putting startTime in the target case as 0.5 and having the endTime as 1. But when I ran mapFields ../sourceCase -consistent I only got the time step folder for 0.5 in the target case.
So far I have only been able to map one time step at the time which is a very slow way of getting where I want.
Does anyone know how to map several time steps at once?
Kind regards,
Maria
hoemmaria is offline   Reply With Quote
Old   January 15, 2018, 09:52
Sebastian Trunk
sisetrun is on a distinguished road
Hello Maria,
You can map the 0.5 by typing
mapFields -sourceTime 0.5 ../sourceCase
in your target Case!
sisetrun is offline   Reply With Quote
Old   November 19, 2024, 23:20
Default Map field problem
  #44
hazem khaled
Hazemabdallah is on a distinguished road
Hi
I followed what is written here and it works with me, but for the new domain, when i open to check the velocity profile at Inlet, I found a different profile from the one I sampled.
Do you know how I can fix this ?
Thanks
Hazemabdallah is offline   Reply With Quote
Map fields every time step sebas OpenFOAM Programming & Development 17 December 5, 2012 14:13
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Matching Velocity and Pressure fields Fluent OpenFoam alimansouri OpenFOAM Running, Solving & CFD 0 January 13, 2009 18:51
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 10:33
