June 5, 2013, 06:28 |
Eddy viscosity ratio in interDyMFoam?
Pal Schmitt
Rep Power: 16 |
I simulated a case of a floating body in shallow water which unfortunately I cannot share. It compares very well to experimental results and everything seems good, until I look at the turbulence modeling (komegaSST RANS model). I want to visualize for the eddy viscosity ratio, For water I used nu=1e-6. m^2/s, Vorticity looks like what i expected but nut gives values of up to 0.001m^2/s. Using the paraview calculator and just dividing nut/nu for the water phase gives very high eddy viscosity ratios... I cannot find the error and the dimensions seem correct, is it still possible that I need to divide by density? Is there a bug in interFOAM in OF 2.1.x? Dividing by density of water gives much more reasonable results but I cannot justify it... Confused.... Cheers, Pal |
March 9, 2014, 03:57 |
esmaeil
Rep Power: 13 |
hi pal
i have the same problem too. how you solved your problem? tnx |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 07:45 |
Eddy viscosity ratio to get the boundary layer thickness | Cecco | CFX | 3 | May 28, 2013 11:17 |
Eddy viscosity ratio and LES | Lance | CFX | 13 | April 29, 2013 19:02 |
Question about eddy viscosity ratio limit | Piti | CFX | 2 | January 17, 2008 16:49 |
