What is "R" in compressibleTwoPhaseEulerFoam bubble column tutorial? |
June 1, 2013, 18:55 |
einat
Rep Power: 14 |
Hello
I am trying to decipher the input files for the two-phase example of a bubble column, in order to be able to modify them for my own application. I understand all the 'transportPropoerties' info except for "R": phase1 { rho 1; rho0 0; R 287; Cp 1007; nu 1.589e-05; kappa 2.63e-2; diameterModel isothermal; isothermalCoeffs { d0 3e-3; p0 1e5; } } Any ideas? Thanks!! |
June 2, 2013, 01:48 |
Ehsan
Rep Power: 26 |
R is clearly the universal gas constant for air.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
June 2, 2013, 12:22 |
einat
Rep Power: 14 |
Thanks immortality. I thought it was something like that, but I'm not sure why the value of R for the second phase (water) is set to be 1e10. Is this a randomly large number, or does it have any meaning?
June 2, 2013, 12:24 |
Ehsan
Rep Power: 26 |
your welcome.where it has defined for water?
------------ I think because its not gas it has given a high value so that its increase in volume due to heat addition in constant pressure is small then specific heat is high.
June 2, 2013, 12:30 |
einat
Rep Power: 14 |
In file transportProperties:
phase2 //liquid { rho 1027; rho0 1027; R 1e10; Cp 4195; nu 3e-7; kappa 0.668; diameterModel constant; constantCoeffs { d 1e-4; } } |
June 2, 2013, 23:51 |
Ehsan
Rep Power: 26 |
i updated the above post if you have seen and also thank you for reputation.
Could you find a formula of R that can argue for liquids?
August 2, 2013, 11:36 |
i need to simulate the sperical bubble growth
Anil Kunwar
Rep Power: 12 |
can the compressibleTwoPhaseEulerFoam used for the simulation of the growth of a spherical bubble? thanking you in advance.
Bubble size distribution : Bubble column | oj.bulmer | CFX | 8 | June 7, 2019 05:03 |
[OpenFOAM] Bubble Column tutorial | physics1 | ParaView | 5 | October 31, 2017 06:18 |
Bubble Column Modelling | dlaw | FLUENT | 24 | October 31, 2017 06:01 |
bubble column | ken | FLUENT | 1 | June 30, 2013 01:18 |
bubble rising in a column | swamysrikanth | Main CFD Forum | 2 | September 27, 2010 08:59 |
