Initial Velocity Field - 2D Turbulence in a Periodic Box |
May 28, 2013, 01:18 |
Angus Hutchison
Rep Power: 13 |
Hi Foamers,
I'm trying to model the two dimensional turbulence of a fluid in a periodic box similar to this example: http://www.youtube.com/watch?v=HIFLOv4eimk I'm having trouble determining the initial conditions, at the moment I'm just trying to get a random velocity field so I can run the program and check that it works. Once I know it's working I will be looking to create an initial velocity field such as the one below, 13 seconds in: http://www.youtube.com/watch?v=-fDwnyi_EkM I've had a bit of a search through the forums and found a thread which suggested using funkySetFields to create a random inital velocity field: http://openfoamwiki.net/index.php/Co...RandomVelocity **EDIT** I'm also using incompressible pimpleFoam I'm not sure how to implement this code into my program, should it be inserted into the 'U' document in the '0' file? I'm very new to this so any help no matter how basic is appreciated! |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 09:30 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 14:52 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
Negative value of k causing simulation to stop | velan | OpenFOAM Running, Solving & CFD | 1 | October 17, 2008 06:36 |
