Zero Pressure with mapFields
Old   May 24, 2013, 10:43
Default Zero Pressure with mapFields
Ignacio
ignacio is on a distinguished road
Hello all,
I am using the results from a URANS simulation as initial values for LES. I use mapFields utility for this.
1) If I use mapFields with ---> source: Coarse mesh, target: Fine mesh
I get he values that make no sense (Zero pressure, negative k and omega, 1000 velocity...)
2) If I use mapFields with ---> source: Fine mesh, target: Coarse mesh.
Then it works fine!
Can anybody explain me why?? Is is a bug?
I need to use the data from the URANS simulation for LES. Is there any other way I can do it without using mapFields?
Thanks a lot =)
Any idea / comment will be more than welcome
ignacio is offline   Reply With Quote
How to get the total pressure in the UDF? zgzhai Fluent UDF and Scheme Programming 3 September 24, 2018 17:12
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 14:30
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
