how to accurately simulate flow around cylinder
Like Tree16Likes
Old   March 18, 2014, 16:44
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Here are my results: http://matveichev.blogspot.fr/2014/0...ex-street.html
alexeym is offline   Reply With Quote
Old   March 19, 2014, 06:24
ok
Maimouna is on a distinguished road
Dear Alexey,
many thanks for your post.
All the best
Maimouna is offline   Reply With Quote
Old   March 19, 2014, 06:59
ok
Dear Alexey,
I have one question please,
what's your accurate result in terms of strouhal number?
tareqkh likes this.
Old   March 19, 2014, 14:30
Alexey Matveichev
You're joking, right?
tareqkh likes this.
Old   March 20, 2014, 05:55
ok
Sorry for that might be silly question, just I would like to know if you checked your convergence in terms of Strouhal number?
Old   March 24, 2014, 03:46
Wentao Zheng
774024952 is on a distinguished road
hi, Maimouna, I'm new with CFD. And I have a question. What's the meaning of Aref and lRef? And how can I calculate them?
Thanks a lot.
774024952 is offline   Reply With Quote
Old   March 24, 2014, 04:17
Wentao Zheng
I've found the explain of the Aref and lRef, thanks.
Old   March 24, 2014, 05:37
ok
Hi. Sorry for late reply. Any question you welcome.
Best wishes
Old   March 26, 2014, 13:07
ok
Dear Alexey,
did you try free vibration of cylinder in flow in your case about flow past a circular cylinder?
I'm doing that now, but I couldn't fix my problem yet. If you try it, I need your help please.
Many thanks in advanced.
Old   May 8, 2014, 02:58
Shuai Wang
Shuai_W is on a distinguished road
Dear Maimouna, I want to simulate the flow around cylinder, and I do it followed step by step. I use openfoam 2.3.0 and the attached case, I excute it via "./Allprepare".however, when I excute "pimpleFoam",there is an error:
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : pimpleFoam
Date : May 08 2014
Time : 13:07:57
Host : "wangshuai-Lenovo-B460"
PID : 6522
Case : /home/wangshuai/OpenFOAM/wangshuai-2.3.0/run/tutorials/incompressible/pimpleFoam/coarse
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
--> FOAM FATAL IO ERROR:
keyword startFace is undefined in dictionary ".defaultFaces"
file: .defaultFaces from line 71 to line 71.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 437.
FOAM exiting
I cannot handle with it, could you help me? Thanks.
File Type: zip mrklein-flow-past-cylinder-27e3de0543ed (1).zip (16.7 KB, 10 views)
Shuai_W is offline   Reply With Quote
Old   May 8, 2014, 06:36
ok
Dear Shuai,
have you tried my one (attached case). Try that case please, if any problem let me know please.
Regards
Old   May 9, 2014, 23:42
Shuai Wang
Dear Maimouna, I tried the attached case yesterday. Everything is Ok when I typed “./Allprepare” in my terminal. After that, when I typed “pimpleFoam” in my terminal, error appeared like:
Create time
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
No finite volume options present
PIMPLE: max iterations = 100
field "(U|p)" : relTol 0, tolerance 0.01
Starting time loop
fieldAverage fieldAverage1:
Starting averaging at time 0
Courant Number mean: 0.0153542679232 max: 0.074259625164
deltaT = 0.00119904076739
Time = 0.00119904076739
PIMPLE: iteration 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00162921759868, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.00157520001085, No Iterations 1
keyword laplacian(rAUf,p) is undefined in dictionary "/home/wangshuai/OpenFOAM/wangshuai-2.3.0/run/tutorials/incompressible/pimpleFoam/circularCylinderNew/system/fvSchemes.laplacianSchemes"
file: /home/wangshuai/OpenFOAM/wangshuai-2.3.0/run/tutorials/incompressible/pimpleFoam/circularCylinderNew/system/fvSchemes.laplacianSchemes from line 37 to line 39.
FOAM exiting
The error suggested that “keyword laplacian(rAUf,p) is undefined in….”, and therefore, I modified the fvSchemes.laplacianSchemes in my system file.
Before modification:
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss cubic corrected;
laplacian((1|A(U)),p) Gauss cubic corrected;
After modification:
laplacianSchemes
default none;
laplacian(rAUf,p) Gauss cubic corrected;
After that, when I typed “pimpleFoam” in my terminal again, it’s Ok. However, I had three questions as follow:
1. What is the function of changeDictionary? I am very confused with this dictionary.
2. Should it will affect the results when I add “laplacian(rAUf,p) Gauss cubic corrected;” in laplacianSchemes?
3. In your case, I find something like “U~” or “P~”, what does the “~” mean?
My results are in the below (attached case). Thank you for your help.
Old   May 11, 2014, 15:49
ok
Dear Shuai,
that is good news that case working in your OpenFOAM version 2.3.0. Regarding your questions
To get more clarification about change[/QUOTE]Dictionary function look at
http://www.cfd-online.com/Forums/openfoam-pre-processing/101179-how-do-i-use-changedictionary-utility.html
When you get through the previous link you can get more idea.
I don't know what that two files mean, but I think they are not affected your result.
All the best.
Old   May 16, 2014, 10:37
ok
Dear Shuai,
recently, I'm using OpenFOAM-2.3.0 because I updated my ubuntu 13.10 to 14.04, which I don't really like. OpenFOAM version that only accompanied with that ubuntu version is 2.3.0. Any way, I tried to work with previous case about circular cylinder that I sent you in the previous post #91, but unfortunately it was gave me the same error that you posted in #92. I solved that problem. It started working and then it stopped by that error
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
 at ??:?
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
 at ??:?
Floating point exception (core dumped)
What does that mean? Any Idea please?
Regards
Old   May 17, 2014, 09:11
Shuai Wang
Dear Maimouna:
Did you solve the problem in #93? I am so sorry to say that I have not encountered with that problem, but I think it may be ralated to your OpenFOAM. When you upgrade the version of Ubuntu, and it may have an influence on your OpenFOAM. I used Ubuntu 12.04,and it works well.
I hope you will solve it soon!
Old   May 18, 2014, 12:07
Sami
Mehrez is on a distinguished road
Hi dear sasanghomi,
Thank you for this interesting reply. However I have 2 main questions in order to understand the changes you have apported to the default icoFoam fvSchemes file:
1- When you switch from: "ddtSchemes { default Euler;" to: "ddtSchemes { default backward;", does the effect on the fluid is that I have less damping ?
2- What does the other modifications (like "limited 0.5") do exactly or how they affect the solution ?
Thank you in advance,
Best regards,
Mehrez
Originally Posted by sasanghomi View Post
Hi ,
I think you use icoFoam as a solver. So I think two parameters have vital role for getting the exact result : 1) discretization method of terms in equations 2)Mesh generation.
So change your fvSchemes and fvSolution as below :
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0;
    U
        solver         BiCG;
        preconditioner   DILU;
        tolerance        1e-05;
        relTol           0;
PISO
   nCorrectors    2;
   nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default backward;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss GammaV 0.5 ;
laplacianSchemes
    default         Gauss linear limited 0.5;
    laplacian(nu,U) Gauss linear limited 0.5;
    laplacian(rUA,pcorr) Gauss linear limited 0.5;
    laplacian(rAU,p) Gauss linear limited 0.5;
interpolationSchemes
    default         linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         limited 0.5;
fluxRequired
    default         no;
    pcorr;
    p;
Hope this helps,
Sasan.
Mehrez is offline   Reply With Quote
Old   April 9, 2015, 10:08
Stephanie
stephie is on a distinguished road
Hello everyone,
at the moment I try to solve a tutorial for channel flow with respect to different LES models which was uploaded for a cours at Chalmers University of technology in 2001. After creating the mesh I wanted to refine the Mesh. I run topoSet. After, I should type in the command : refineMesh -dict -overwrite. And here is the first mistake:
Create time
Create polyMesh for time = 0
Mesh edge statistics:
x aligned : number:16376 minLen:0.005 maxLen:0.005
y aligned : number:16056 minLen:0.005 maxLen:0.005
z aligned : number:8232 minLen:0.005 maxLen:0.005
other : number:0 minLen:1e+15 maxLen:-1e+15
Refining according to refineMeshDict
cannot open file
file: /home/stephanie/OpenFOAM/stephanie-2.3.1/run/smagorinsky_mini/-overwrite at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
It didn't work. When I typed in <refineMesh> it was okay. Why does this command don't work?
The next step should be to run the simulation by <pyFoamPlotRunner.py pimpleFoam >& log and it also do not work.
There is still the mistake: pyFoamPlotRunner command not found
I had a look in a lot of discussions, but I couldn't find an answer.. because pyFoam is alreay installed.
So i tried to type in <pimpleFoam> to start the simulation and here ist the next mistake:
--> FOAM FATAL IO ERROR: keyword laplacian(rAUf,p) is undefined in dictionary "/home/stephanie/OpenFOAM/stephanie-2.3.1/run/smagorinsky_mini/system/fvSchemes.laplacianSchemes" file: /home/stephanie/OpenFOAM/stephanie-2.3.1/run/smagorinsky_mini/system/fvSchemes.laplacianSchemes from line 45 to line 51. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 437. FOAM exiting
I would be grateful if anyone might help me to solve this tutorial.
Thank you so much, nice regards,
Stephie
stephie is offline   Reply With Quote
Old   April 9, 2015, 11:36
Sami
Hi dear Stephie,
After refining the mesh you should interpolate your fields (U, p... for example) from the old mesh to the new fine mesh. Then, you can start your simulation.
There is a function in OpenFoam to perform interpolation.
Regards,
Mhrz
Originally Posted by stephie View Post
Hello everyone,
Create time
cannot open file
FOAM exiting
Stephie
Old   April 9, 2015, 12:27
Alexey Matveichev
cannot open file
The command in fact should be
refineMesh -dict system/refineMeshDict -overwrite
Guess this is again due to OpenFOAM's version incompatibility.
And this again is due to modification in 2.3.1. You have this line in fvSchemes:
laplacian((1|A(U)),p) Gauss linear corrected;
now it should be written as
laplacian(rAUf,p)  Gauss linear corrected;
And finally about pyFoamPlotRunner error, it is not pyFoamPlotRunner, it is pyFoamPlotRunner.py.
stephie likes this.
Old   April 10, 2015, 05:18
Stephanie
Good morning Alexey,
you are amazing - thank you so much. After typing in the correct command to refine the Mesh it worked. Now it looks like the image in the description
Also the second hint was right, I changed this line in fvSchemes and the simulation run.
The only thing, which did not work is pyFoamPlotRunner.py. There is still the mistake command not found. Maybe I miss something when I installed OpenFoam...do you have any idea?
But it doesn't matter... I'm happy, the simulation run.
Thank you so much for your help
[Other] OpenFoam Flow over a Circular Cylinder WolfgangS. OpenFOAM Meshing & Mesh Conversion 12 March 3, 2014 11:53
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 18:51
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 11:05
Flow induced vibration of a mobile cylinder Hooman Main CFD Forum 0 December 31, 2010 09:48
