Problem running OpenFOAM 2.2.x in parallel in Centos 5 |
#21 |
Rep Power: 12 ![]() |
Hello Bruno,
Sorry for the late reply. Actually the link that you provided solved the problem for my case. More specific I followed the instructions in the last post of the thread and then the instructions in the second post of the following thread: http://www.cfd-online.com/Forums/ope...e-openmpi.html Now I can run OpenFoam 2.3.0 in parallel, however I can not use decomposePar. So for now I use decomposePar from OpenFoam 2.1.1 Thanks a lot for the help! Best regards, Greg |
#22 | |||
Hi guys!
For me the tip from linnemann Quote:
Surprisly the solver runs well on the login node of the RHEL Server in parallel mode, but when I start it via the queueing system I get the following error message in a log file: Quote:
So, would you be so kind to make your suggestions, what is the reason and how can I fix this issue? Cheers, Alex
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
#23 |
Yejun Gong
Rep Power: 18 ![]() |
I met the same problem before. And it is solved by recompiling the ThirdParty (Allwclean, and then Allwmake).
#24 |
H. Omar
Rep Power: 13 ![]() |
Hi Alexander,
Did you find the solution about your issue? I have the same problem and i tried to resolve by the manner proposed by linnemann but i didn't succeed I need help please, Thanks |
#25 | |
Dear stater,
I've just solved a problem in my case. It was: 1. Rebuilding the ThirParty with system gcc 2. Running my tasks with the mpirun options: Quote:
#26 |
I also successfully installed 2.3.x git version on CentOS 5.9 just following instructions:
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL Thank you, Bruno! )))
#27 | |
Fengjiao Bian
#28 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
#29 | |
Fengjiao Bian
http://www.cfd-online.com/Forums/ope...tml#post599384. I pasted some information in it. Thank you for your help, best regards, Jiaojiao |
#30 | |
Tenglubao
#31 |
ali alkebsi
Rep Power: 14 ![]() |
Dear all,
I have the same problem with the new OF1606+ I tried which mpirun and it is the one included with the OF1606+ I can't wclean and allwmake the mpi becuase of permissions under docker containers Any ideas please |
#32 | |
Saleh Abuhanieh
Rep Power: 8 ![]() |
Hi Foamers, I just wanted to highlight that the above solution is still valid. I had the same problem with foam-extend 4.0, I think due to have more than one version of mpi in my machine. I've changed the WM_MPLIB for SYSTEMOPENMPI then recompiled foam and it works! |
#33 | |
Ali Shayegh
Rep Power: 10 ![]() |
I use foam-extend-4.0. There is no 'PStream' directory under $FOAM_SRC in order to make the changes that you've mentioned. ![]() |
#34 |
Ferenc Safranyik
Rep Power: 5 ![]() |
Hi linnemann,
I faced with exactly the same problem on Ubuntu 20.04 with HELYX-OS 2.4 and OpenFoam 4.1. I found your solutions which was worked for others as well, however in case of my setup there are no directories as you mentioned hence I am not able to run the suggested commands. Do you have any idea how should I modify your code? Thanks in advance, Feri |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
Problem in running job in parallel | Tarak | OpenFOAM | 0 | March 19, 2011 20:34 |
Problem running a parallel fluent job on local machine via mpd | highhopes | FLUENT | 0 | March 3, 2011 05:07 |
Running Problem using Openfoam solver | cfd_staruser | OpenFOAM | 5 | August 14, 2009 02:28 |
