ignition reactingFoam
Old   May 7, 2013, 17:11
Default ignition reactingFoam
Camille
camille131 is on a distinguished road
I'm trying to compute an axisymmetric flow field with combustion with the reactingFoam solver. I m on the 2.1.1 OF version.
I consider premixed CH4 + air inlet.
Here is my case : https://www.dropbox.com/s/mdu00b2iajf6qzx/set6.zip
But I have some trouble to ignite it..
I don't know the right length for my patch field (my chamber is 50 cm long en 10 cm ray) one can see the patch at time 0.1
I don't know either the Temperature to set (adiabatic T : 2000 K, or autoignition temperature of methane ie: 850 K ?)
In both possibility the temperature rises and then decrease instantaneously.
Should I change other parameters? in fvSolution, fvScheme, cntrolDict ?
I put a max Co number of 0.2 ...
Thank you in advance for you help,
I'm really upset with that issue since I'm working on it for weeks...
camille131 is offline   Reply With Quote
Old   May 22, 2013, 13:29
Camille
nobody can help me?
Ignition in reactingFoam pas32 OpenFOAM Programming & Development 4 August 13, 2014 10:00
simulation ignition reactingfoam vahidzanganeh OpenFOAM 0 September 6, 2012 03:09
Ignition point in reactingFoam? lfgmarc OpenFOAM Programming & Development 0 July 11, 2011 19:00
MPI Aborts when using reactingFoam with cyclic BC in parallelization jose_rodrig OpenFOAM 1 February 14, 2011 04:05
Ignition modeling Julie Polyakh Siemens 0 May 20, 2004 09:05
