codeStream Help
Old   May 7, 2013, 13:48
Default codeStream Help
physics1 is on a distinguished road
Hi Eveyrone,
I'm currently using setFields to create two different density regions in my code but need one of them, which is ciruclar, to have a gaussian distribution based on the distance from the center. Is it possible to input a non uniform value into set fields and if so can I do the calculation using codestream?
physics1 is offline   Reply With Quote
codestream, setfields
codeStream in SetFieldsDict physics1 OpenFOAM Running, Solving & CFD 1 June 14, 2013 11:58
Change deltaT using codeStream whatsoever OpenFOAM Running, Solving & CFD 1 April 30, 2013 03:53
Time varying surfaceNormalFixedValue BC with codeStream francois OpenFOAM Pre-Processing 2 April 5, 2013 15:19
Using #codeStream to set initial field for parallel run Hisham OpenFOAM Running, Solving & CFD 7 June 25, 2012 10:48
Using codestream in controlDict pad OpenFOAM Running, Solving & CFD 0 April 11, 2012 04:59
