decomposePar pointfield
Like Tree4Likes
Old   May 6, 2013, 00:27
Default decomposePar pointfield
xinguang cui
flying is on a distinguished road
Dear All foamers:
I have met a problem when I use decomposePar to decompose the field which has a dynamic boundary. The boundary motion is described with a pointfield. The problem appears when the decompose plane crosses the dynamic boundary. Otherwise, it seems Ok. In additiion, I have found that the problem has been encountered by other users, but it seems that there are nobody to solve it. My error information as follows:
[6] --> FOAM FATAL IO ERROR:
[6] size 6977 is not equal to the given value of 933
[2] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor2/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013.
[2]
[2] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[2] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236.
[2]
FOAM parallel run exiting
[2]
[6]
[6] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor6/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013.
[6]
[6] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[6] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236.
[6]
[6]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] size 6977 is not equal to the given value of 944
[0]
[0] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor0/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013.
[0]
[0] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[0] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236.
[0]
[0]
[4]
[4] --> FOAM FATAL IO ERROR:
[4] size 6977 is not equal to the given value of 866
[4]
[4] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor4/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013.
[4]
[4] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[4] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236.
[4]
[4]
[7]
[7] [3]
[3]
[3] --> FOAM FATAL IO ERROR:
[3] size 6977 is not equal to the given value of 876
[3]
[3]
[7] --> FOAM FATAL IO ERROR:
[7] size 6977 is not equal to the given value of 1025
[7]
file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor3/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013.
[3]
[3] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[3] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236[7] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor7/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013.
[7]
[7] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[7] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C.
[3]
[3]
at line 236.
[7]
[7]
[1]
[1]
[1] --> FOAM FATAL IO ERROR:
[1] size 6977 is not equal to the given value of 840
[1]
[1] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor1/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013.
[1]
[1] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[1] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236.
[1]
[1]
[5]
[5]
[5] --> FOAM FATAL IO ERROR:
[5] size 6977 is not equal to the given value of 808
[5]
[5] file: /gpfs/home/xgcui/OpenFOAM/xgcui-2.0.0/run/test1/flow3d-movingmesh-f-3/processor5/0/pointMotionU::boundaryField::WALL1 from line 26 to line 7013.
[5]
[5] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[5] in file /usr/local/OpenFOAM/OpenFOAM-2.0.0/src/OpenFOAM/lnInclude/Field.C at line 236.
[5]
Does anybody have any ideas on it? Would you please give me some hints on it?
Best wishes!
flying is offline   Reply With Quote
Old   May 6, 2013, 15:32
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
as you wrote in the PM you have an error while decomposing.
Like I interprete the error you have the files in 0 always initialised with a other mesh. Maybe thats the reason!
Tobi is offline   Reply With Quote
Old   May 6, 2013, 23:16
xinguang cui
Hey Tobi:
Many thanks for your reply. In this case, how may I solve the problem? Please give me some hints on it.
Originally Posted by Tobi View Post
Old   May 7, 2013, 13:25
Tobi's Avatar
Tobias Holzmann
1. use decomposePar -force
2. check in your folder 0 the files pointMotionU if there are any lists in it. If yes you have to create that folder new. I am not familiar with moving meshes
Old   May 7, 2013, 22:14
xinguang cui
Dear Tobi:
Thanks so much for your reply. It stil doesn't work. However, I found that the problem comes from the number of p0 is not equal to the mesh point number. If I change the data in the pointMotionU and make the value uniform and delete the number of value. It will work.
Old   May 7, 2013, 22:36
xinguang cui
Hey Bruno and all fomers:
I upload a simple case, it is orginally downloaded from the link as follows:
http://www.tfd.chalmers.se/~hani/kur...atchDeform.tgz
It is orginally solved with icoFoam, but I have changed it to the pimpleDyMFoam.
The lib file is for the moving boundary.
As my case is very large and it is changed based this case, then I uploaded this case. My problem is the same as it.
It will be great for any further suggestions.
Originally Posted by flying View Post
Dear Tobi:
Old   May 19, 2013, 08:02
Retired Super Moderator
Bruno Santos
Hi Xinguang Cui,
I've finally taken a look into this and I cannot find any problems. I've tested on OpenFOAM 2.2.x, 2.0.x and 2.0.1 and I had no problems in performing the following steps:
wmake libso libMyPolynomVelocity
cd movingCyl1
blockMesh
decomposePar
I do not have an installation of OpenFOAM 2.0.0, so I cannot confirm if this is a version problem.
Best regards,
Bruno
Old   May 19, 2013, 10:51
xinguang cui
DEAR BRUNO:
Thanks for the information. Would you please put up the decomposePar file? I would like to see the way to decompose the mesh.
bEST WISHES
Originally Posted by wyldckat View Post
Hi Xinguang Cui,
cd movingCyl1
blockMesh
decomposePar
Best regards,
Bruno
Old   May 19, 2013, 11:49
Bruno Santos
Hi Xinguang Cui,
I didn't change anything on the "decomposeParDict". I used the one provided in your test case.
All I did was clean up a bit the folder "0", by removing some strange files named ".goutputstream*" and one named "pointMotionU~".
Best regards,
Bruno
Old   May 19, 2013, 12:02
xinguang cui
Hey Bruno:
Thanks sor your reply. Have ever tried to run it? I also can decompose it, however it shows problem when it runs the case using pimpleDyMFoam.
I also tried it in 2.2 0 and 2.1.1.
Thanks and best wishes!
Hi Xinguang Cui,
cd movingCyl1
blockMesh
decomposePar
Best regards,
Bruno
Old   May 19, 2013, 13:44
Bruno Santos
Hi Xinguang Cui,
The error was completely different from the one originally reported... and the case you prepared seems to be completely different from the initial report... and on top of that, the case was not fully prepared to run...
Anyway, the attached case "movingCyl1_22x.tar.gz" runs fine on OpenFOAM 2.2.x. To run it:
./Allrun
To clean it up:
./Allclean
Changes made:
  • I had to add the missing files "transportProperties" and "turbulenceProperties" to the "constant" folder.
  • Added the "All*" scripts, to make it easier to run the case. Keep in mind that the "run*" commands that are inside these scripts will only work inside them.
  • I added the "processor" block to the file "pointMotionU". After decomposition, the file has to be copied once again to all of the processor folders, because decomposePar does not fully understand what this boundary condition is.
For more information, study the tutorial "incompressible/pisoFoam/les/motorBike".
Best regards,
Bruno
Old   May 21, 2013, 02:19
Marhamat Zeinali
marhamat is on a distinguished road
Hi Bruno
It seems that the problem still exists. when I run the attached case in parallel I still see the reported problem in this page. I have same problem with my case, when I run it with pimpleDyMFoam in parallel.
has anybody found a solution for this problem?
Best Regards,
Marhamat
marhamat is offline   Reply With Quote
Old   May 21, 2013, 11:18
xinguang cui
Dear BRUNO:
Thanks so much for your reply, what your mention is right. I attached a different case, which is different with my orginal case because its size is small enough to attach.
I will try the case you attached, and give you feedback ASAP.
3X
Hi Xinguang Cui,
./Allrun
To clean it up:
./Allclean
Changes made:
Best regards,
Bruno
Old   May 21, 2013, 18:44
Bruno Santos
Greetings to all!
@Marhamat:
Which specific OpenFOAM version are you using?
@Xinguang:
OK
Best regards,
Bruno
Old   May 21, 2013, 23:40
xinguang cui
Hey Bruno:
Many thanks for your reply and help. I have test in 2.2.0 and it works in this way. However, I found another bug in this case. When I reconstuctPar -lastestTime, and then I decomposePar it
Decomposing mesh region0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod simple
Finished decomposition in 0.01 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
Processor 0
Number of cells = 4000
Number of faces shared with processor 1 = 160
Number of faces shared with processor 2 = 250
Number of processor patches = 2
Number of processor faces = 410
Number of boundary faces = 1210
Processor 1
Number of faces shared with processor 0 = 160
Number of faces shared with processor 3 = 250
Processor 2
Number of faces shared with processor 0 = 250
Number of faces shared with processor 3 = 80
Number of faces shared with processor 4 = 250
Number of processor patches = 3
Number of processor faces = 580
Number of boundary faces = 1180
Processor 3
Number of faces shared with processor 1 = 250
Number of faces shared with processor 2 = 80
Number of faces shared with processor 5 = 250
Processor 4
Number of faces shared with processor 5 = 160
Processor 5
Number of faces shared with processor 4 = 160
Number of processor faces = 1400
Max number of cells = 4000 (0% above average 4000)
Max number of processor patches = 3 (28.5714% above average 2.33333)
Max number of faces between processors = 580 (24.2857% above average 466.667)
Time = 0.08
size 0 is not equal to the given value of 121
file: /home/cui/OpenFOAM/cui-2.2.0/run/test1/movingCyl1_22x/0.08/pointMotionU.boundaryField.cubeY from line 45 to line 51.
in file /opt/openfoam220/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
If you like, please give me some hints. Of course, it is not necessary to debug it.
Greetings to all!
@Marhamat:
@Xinguang:
OK
Best regards,
Bruno
Last edited by wyldckat; May 22, 2013 at 19:49. Reason: Added the [CODE] delimiters
Old   May 22, 2013, 03:18
Marhamat Zeinali
Dear Bruno
Now when I run the attached case "movingCyl1_22x.tar.gz" on OpenFOAM 2.1.1. by using the Code: ./Allrun
I get the below error:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : pimpleDyMFoam -parallel
Date   : May 22 2013
Time   : 02:08:08
Host   : "hydrocoeff-System-Product-Name"
PID    : 11868
Case   : /home/hydrocoeff/Downloads/movingCyl1_22x
nProcs : 4
Slaves :
3
"hydrocoeff-System-Product-Name.11869"
"hydrocoeff-System-Product-Name.11870"
"hydrocoeff-System-Product-Name.11871"
Pstream initialized with:
    floatTransfer     : 0
    nProcsSimpleSum   : 0
    commsType         : nonBlocking
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
// using new solver syntax:
cellMotionU
    solver          PCG;
    preconditioner  DIC;
    tolerance       1e-08;
    relTol          0;
motionU
    solver          PCG;
    preconditioner  DIC;
    tolerance       1e-06;
    relTol          0;
Selecting motion solver: velocityLaplacian
[0]
[0]
[0] keyword diffusivity is undefined in dictionary "/home/hydrocoeff/Downloads/movingCyl1_22x/processor0/constant/dynamicMeshDict"
[0]
[0] file: /home/hydrocoeff/Downloads/movingCyl1_22x/processor0/constant/dynamicMeshDict from line 18 to line 31.
[0]
[0]     From function dictionary::lookupEntry(const word&, bool, bool) const[3]
[3]
[3] keyword diffusivity is undefined in dictionary "/home/hydrocoeff/Downloads/movingCyl1_22x/processor3/constant/dynamicMeshDict"
[3]
[3] file: /home/hydrocoeff/Downloads/movingCyl1_22x/processor3/constant/dynamicMeshDict from line 0 to line 0.
[3]
[3]     From function dictionary::lookupEntry(const word&, bool, bool) const
[3]     in file db/dictionary/dictionary.C at line 400.
[3]
[3]
[0]     in file db/dictionary/dictionary.C at line 400.
[0]
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[1]
[1]
[2]
[2]
[2] --> FOAM FATAL IO ERROR:
Regards,
Marhamt
Last edited by wyldckat; May 22, 2013 at 19:50. Reason: Added the [CODE] delimiters
Old   May 22, 2013, 06:40
Marhamat Zeinali
By updating my OF version to OF-2.2.0, now I can run the attached case in parallel. but in my own case I get the below error:
Create time
[0]
[0]
[0] --> FOAM FATAL IO ERROR: [2]
[2]
[0] keyword velocityLaplacianCoeffs is undefined in dictionary "/home/hydrocoeff/Desktop/MyDocuments/pimpleDymFoam/Elips1Par/processor0/constant/dynamicMeshDict"
[0]
[0] file: /home/hydrocoeff/Desktop/MyDocuments/pimpleDymFoam/Elips1Par/processor0/constant/dynamicMeshDict from line 18 to line 23.
[0]
[0]     From function dictionary::subDict(const word& keyword) const
[0]     in file db/dictionary/dictionary.C at line 608.
[0]
There is not dynamicMeshDict in each processor files.
so what is the reason of this error?
Thanks alot,
Marhamat.
Old   May 22, 2013, 09:54
Marhamat Zeinali
By changing the dynamicMeshDic the problem solved.
Thanks,
Marhamat
Old   May 22, 2013, 20:29
Bruno Santos
Hi Marhamat and Xinguang,
Marhamat sent me a private message with pretty much the same problem that Xinguang has got right now.
The problem is not an easy one to solve and attached is only the first part of the solution, namely a case that should work... but doesn't work because of the broken "libMyPolynomVelocity" library.
I'm not sure when I'll be able to look into this library code... I'll try to look at it tomorrow.
In the meantime, please study attached case file.
And please also study the post from the second link in my signature... namely this one: How to post code using [CODE]
Best regards,
Bruno
marhamat, 88481101 and meisam_khan like this.
Old   May 26, 2013, 09:43
Bruno Santos
I've finally managed to look at this and make things work.
A description of the necessary changes:
  • On "libMyPolynomVelocity", I had to fix the missing entries at the method "write()". It was missing the keywords such as "RR".
  • On the case itself:
    • It no longer needs to use changeDictionary, since it now properly writes all of the necessary keywords.
    • I had to modify "decomposeParDict" to use:
      • "preservePatches", so that the patches that use "libMyPolynomVelocity" will not be broken between processors.
      • Changed the decomposition method from "simple" to "scotch". This is to make it easier for "preservePatches" to work properly.
Attached are the zip files with the working code and case.
edit: I had a look at how it would be possible to avoid the need for "preservePatches". From what I can understand, the problem is that the
"libMyPolynomVelocity" library does not implement all of the necessary methods and constructors. Compare with the class "sixDoFRigidBodyDisplacementPointPatchVectorFi eld" of the same kind of mesh manipulation:
src/postProcessing/functionObjects/forces/pointPatchFields/derived/sixDoFRigidBodyDisplacement/sixDoFRigidBodyDisplacementPointPatchVectorField.H
src/postProcessing/functionObjects/forces/pointPatchFields/derived/sixDoFRigidBodyDisplacement/sixDoFRigidBodyDisplacementPointPatchVectorField.C
Best regards,
Bruno
marhamat likes this.
Last edited by wyldckat; May 26, 2013 at 10:00. Reason: I had forgotten that dynamic meshes are automatically reconstructed by decomposePar! - Also see "edit:"
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
