May 2, 2013, 05:12 |
T Junction Stability
Ignacio
Rep Power: 13 |
Hello Foamers,
I am running a T-Junction case (both water and pipes), using the chtMultiRegionFoam solver. First I run a steady state and now I am doing a URANS with the steady state output as initial value. I use k-OmegaSST Low Reynolds model. I don't know why but the simulation always crashes after 3 iterations... I changed parameters in fvSolution and fvSchemes, but still, it's always after 3 iterations. My time step is so low that the initial Courant is only 0.1 The problem is at the outflow pipe. Inflow is in another place with much higher velocity but it's working fine. I attach some pictures No problems at all in checkMesh. Any idea of how to solve this? I would really appreciate any kind of comments. Mesh.jpg Courant.jpg |
May 2, 2013, 05:15 |
Ignacio
Rep Power: 13 |
fvSolution
solvers { rho { solver PCG preconditioner DIC; tolerance 1e-7; relTol 0; } rhoFinal { $rho; tolerance 1e-7; relTol 0; } p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother DICGaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } p_rghFinal { $p_rgh; tolerance 1e-7; relTol 0; } h { solver GAMG; tolerance 1e-10; relTol 0.01; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } hFinal { $h; tolerance 1e-10; relTol 0; } "(U|k|epsilon|omega)" { solver PBiCG; preconditioner DILU; tolerance 1e-7; relTol 0.1; } "(U|k|omega|R)Final" { $U; tolerance 1e-7; relTol 0; } } PIMPLE { momentumPredictor on; //Accounts for variations by reconstructing the flux nCorrectors 3; //How many times the pressure equation is solved in outer loop nOuterCorrectors 2; //Outer Piso loop nNonOrthogonalCorrectors 3; residualControl { h 1e-3; } } relaxationFactors { fields { rho 1; p_rgh 0.5; } equations { U 0.3; h 0.5; nuTilda 0.5; k 0.5; epsilon 0.5; omega 0.5; "ILambda.*" 0.5; } } Code:
ddtSchemes { default backward; } gradSchemes { default Gauss linear; grad(p) cellLimited Gauss linear 1; grad(U) cellLimited Gauss linear 1; } divSchemes { default Gauss limitedLinear 1; div(phi,U) Gauss filteredLinear2V 0.2 0; div((muEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 1; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.333; } fluxRequired { default no; p_rgh; } Code:
U { internalField uniform (0 0 0); boundaryField { ".*" { type fixedValue; value uniform (0 0 0); } COLDINLETMAXX { type timeVaryingMappedFixedValue; setAverage off; offset (0 0 0); } COLDINLETMINX { type timeVaryingMappedFixedValue; setAverage off; offset (0 0 0); } HOTINLETMAXZ { type timeVaryingMappedFixedValue; setAverage off; offset (0 0 0); } HOTINLETMINZ { type timeVaryingMappedFixedValue; setAverage off; offset (0 0 0); } OUTLETMAXZ { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } OUTLETMINZ { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } } } T { internalField uniform 333.15; boundaryField { "WATER_to_.*" { type compressible::turbulentTemperatureCoupledBaffleMixed; neighbourFieldName T; kappa fluidThermo; kappaName none; value uniform 333.15; } HIHGHREFLUX { type compressible::turbulentTemperatureCoupledBaffleMixed; neighbourFieldName T; kappa fluidThermo; kappaName none; value uniform 333.15; } COLDINLETMAXX { type fixedValue; value uniform 333.15; } COLDINLETMINX { type fixedValue; value uniform 333.15; } HOTINLETMAXZ { type fixedValue; value uniform 549.15; } HOTINLETMINZ { type fixedValue; value uniform 549.15; } OUTLETMAXZ { type inletOutlet; inletValue uniform 333.15; value uniform 333.15; } OUTLETMINZ { type inletOutlet; inletValue uniform 333.15; value uniform 333.15; } TOP { type zeroGradient; } BOTTOM { type zeroGradient; } OUTERRAD { type zeroGradient; } HIGHREADIAB { type zeroGradient; } } } p_rgh { internalField uniform 72e5; boundaryField { ".*" { type buoyantPressure; value uniform 72e5; } COLDINLETMAXX { type zeroGradient; } COLDINLETMINX { type zeroGradient; } HOTINLETMAXZ { type zeroGradient; } HOTINLETMINZ { type zeroGradient; } OUTLETMAXZ { type fixedValue; value uniform 72e5; } OUTLETMINZ { type fixedValue; value uniform 72e5; } } } p { internalField uniform 72e5; boundaryField { ".*" { type calculated; value uniform 72e5; } } } //------------------------------------------------ // Turbulent Low Reynolds k-OmegaSST model //------------------------------------------------ omega { internalField uniform 40; boundaryField { ".*" { type compressible::omegaWallFunction; value uniform 1000; } COLDINLETMAXX { type fixedValue; value uniform 40; } COLDINLETMINX { type fixedValue; value uniform 40; } HOTINLETMAXZ { type fixedValue; value uniform 40; } HOTINLETMINZ { type fixedValue; value uniform 40; } OUTLETMAXZ { type inletOutlet; inletValue uniform 40; value uniform 40; } OUTLETMINZ { type inletOutlet; inletValue uniform 40; value uniform 40; } } } k { internalField uniform 0.0005; boundaryField { ".*" { type fixedValue; value uniform 1e-10; } HIGHREADIAB { type compressible::kqRWallFunction; value uniform 1e-10; } HIGHREFLUX { type compressible::kqRWallFunction; value uniform 1e-10; } COLDINLETMAXX { type fixedValue; value uniform 0.0005; } COLDINLETMINX { type fixedValue; value uniform 0.0005; } HOTINLETMAXZ { type fixedValue; value uniform 0.0005; } HOTINLETMINZ { type fixedValue; value uniform 0.0005; } OUTLETMAXZ { type inletOutlet; inletValue uniform 0.0005; value uniform 0.0005; } OUTLETMINZ { type inletOutlet; inletValue uniform 0.0005; value uniform 0.0005; } } } mut { internalfield uniform 0; boundaryField { ".*" { type mutLowReWallFunction; value uniform 0; } HIGHREADIAB { type mutkWallFunction; value uniform 1e-10; } HIGHREFLUX { type mutkWallFunction; value uniform 1e-10; } COLDINLETMAXX { type calculated; } COLDINLETMINX { type calculated; } HOTINLETMAXZ { type calculated; } HOTINLETMINZ { type calculated; } OUTLETMAXZ { type calculated;; } OUTLETMINZ { type calculated; } } alphat { internalfield uniform 0; boundaryField { ".*" { type alphatWallFunction; value uniform 0; } COLDINLETMAXX { type calculated; value uniform 0; } COLDINLETMINX { type calculated; value uniform 0; } HOTINLETMAXZ { type calculated; value uniform 0; } HOTINLETMINZ { type calculated; value uniform 0; } OUTLETMAXZ { type calculated; value uniform 0; } OUTLETMINZ { type calculated; value uniform 0; } } Last edited by ignacio; May 2, 2013 at 05:34. |
May 2, 2013, 09:50 |
Lieven
Rep Power: 23 |
A few things you can easily try:
1. Set the time step 10x smaller such that courant number < 1.0 2. Take upwind-schemes to increase stability. It might not be interestiging from numerical point of view, but at this moment the priority is not obtaining 'a' result and not the 'best' result. Later-on you can switch to 2nd order schemes with the upwind-solution as initial condition. 3. First run a few timesteps with potentialFoam to improve the initial conditions Cheers, L |
May 2, 2013, 10:11 |
Ignacio
Rep Power: 13 |
Thanks for the response Lieven!
1 and 2 I have already tried them. But I don't see any improvement in the simulation. I will see what happens with the potentialFoam I found out a strange thing playing around with the case. If I change the density at thermphysicalProperties file it's stable! (the commented part is what I changed) Although the min/max temperature start decreasing/increasing with the iteration Code:
thermoType { type heRhoThermo; // Thermophysical model based on sensible enthalpy mixture pureMixture; // Only water transport polynomial; // (mu, k) T dependant transport properties. T in Kelvin thermo hPolynomial; // (Cp) T dependant thermodynamic properties. T in Kelvin equationOfState icoPolynomial; // (rho) Incompressible polynomial eq of state specie specie; energy sensibleEnthalpy; } mixture { specie { nMoles 1; molWeight 18; // Water } equationOfState { rhoCoeffs<8> (863.76 0 0 0 0 0 0 0); //(856.76 1.2436 -0.0026 0 0 0 0 0); //Density [kg/m3] = 856.76 - 1.2436*T - 0.0026*T^2 } Thanks a lot |
May 2, 2013, 10:27 |
Lieven
Rep Power: 23 |
Ok, best thing to do then is first let the simulation run with
(863.76 0 0 0 0 0 0 0) next with (863.76 1.2436 0 0 0 0 0 0) and finally with (863.76 1.2436 -0.0026 0 0 0 0 0) So always start from the previous simulation as initial condition. If the simulation gets unstable, try to figure out why. . By the way, you write 1.2436 but according to your correlation it should be -1.2436 |
May 2, 2013, 11:44 |
Ignacio
Rep Power: 13 |
Oh, mistake. The code is correct, the commented equation isn't.
We are now doing the process that you said. I will tell you how it goes. Thanks again Lieven! |
when I use multi block the condition of stability can not be fulfilled | mostafa_khan | FLOW-3D | 2 | April 19, 2012 13:17 |
stability and number of processors ?? | sersunzo | OpenFOAM Running, Solving & CFD | 0 | June 9, 2009 12:45 |
Junction Box | Anil | CFX | 2 | June 27, 2006 11:18 |
junction box routine | Lexi | CFX | 2 | January 21, 2004 05:55 |
Solving linear stability eq. | K S Chang | Main CFD Forum | 3 | January 19, 2004 17:01 |
