April 28, 2013, 09:57 |
edcSimpleFoam
Vivek
Rep Power: 13 |
I am a newbie to both openfoam. and i am using version 2.2.0. I am trying to replicate the below problem. http://www.personal.psu.edu/dab143/O...ist_slides.pdf http://openfoamwiki.net/index.php/Fi...Solvers.tar.gz but the problem is I cannot execute edcSimpleFoam after my problem is set Why? What should i execute in command window to run this simlation ?? i typed edcSimpleFoam... Thanks Vivek |
April 28, 2013, 13:12 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Vivek,
You should have tested the links before you posted The correct ones are from another post of yours that I'll quote: Quote:
Oh no... I had already started writing instructions on how to build it, but apparently it will only work on very old versions of OpenFOAM Possibly OpenFOAM 1.5 or 1.6... Some other threads on this topic:
Once you have 1.6-ext built and working, run the following commands: Code:
mkdir -p $WM_PROJECT_DIR cd $WM_PROJECT_DIR git clone git://git.code.sf.net/p/ofca/code ofca-code cd ofca-code Good luck! Bruno
April 28, 2013, 22:31 |
Vivek
Rep Power: 13 |
Thank you Bruno!
I understand that it runs in older version of OpenFOAM from many threads! Is reactingFoam and alternative to edcSimpleFoam? If Yes, i shall concentrate more on running my simulation without errors in reactingFoam. Thanks! |
April 29, 2013, 18:41 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Vivek,
edcSimpleFoam seems to have been created around the time OpenFOAM 1.4 to 1.6 were the latest versions, at least from some of the papers I've quickly looked at. OpenFOAM right now is at version 2.2, so I can only wish that reactingFoam was already good enough or better than edcSimpleFoam, but unfortunately I simply don't know You can try and have a look at the release history, to see how much it has evolved over time: http://www.openfoam.org/download/history.php Nonetheless, if you're trying to simulate flametlets or similar, try: https://github.com/shor-ty/flameletModel-2.2.x Best regards, Bruno
October 9, 2013, 07:09 |
Peter Bishop
Rep Power: 14 |
anyone succeded in compiling edcSimpleFoam in OF 2.2.x? |
edcsimplefoam |
EDCsimpleFOAM | dreamilam | OpenFOAM Running, Solving & CFD | 10 | August 9, 2016 06:31 |
Problem edcSimpleFoam (combustion) | rafi525 | OpenFOAM Running, Solving & CFD | 5 | October 21, 2013 05:44 |
Segmentation fault in edcSimplefoam | dreamilam | OpenFOAM Programming & Development | 1 | July 25, 2013 09:59 |
