Stokes Flow for a moving bubble
Old   April 16, 2013, 14:59
Default Stokes Flow for a moving bubble
Paul B
pbarc is on a distinguished road
Hello Foamers,
I am trying to simulate stokes flow (low reynolds number) for a bubble (or droplet) and compare the results to the analytical solution.
I am using the interFoam solver with the following fluid properties (all units are SI units):
rho = 1000, nu = 1e-2
rhoB = 900, nuB = 1.11e-2
The radius of the bubble is 5mm. The Reynolds is 0.01.
As I increase the mesh resolution the average bubble speed converges onto to the analytical, but if I continue to increase the resolution the average speed falls below the analytical (see attached image, R/4 indicates that a dimension of a square mesh element is 1/4 that of the radius).
I am using a fixed time step and the maximum Courant number for all simulations is less than 0.09.
Could anyone help me as to why the increasing the mesh resolution would cause the solution to go past that of the analytical value? Is it possible to have to fine of a mesh? Any insight on to what I may be doing wrong would be much appreciated.
Sorry that the question is so long, but I wanted to add as much relevant information as I could.
Thanks,
Paul
pbarc is offline   Reply With Quote
grid resolution
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 01:02
Help on bubble flow experiment dataset X.-L. Chan Main CFD Forum 3 October 29, 1999 00:24
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
