interFoam running blowing up
Old   April 15, 2013, 07:04
Default interFoam running blowing up
sandy
sandy13 is on a distinguished road
Dear Foamers,
I am doing a liquid jet simulation using interFoam, my geometry is OK according to checkMesh. After setting the suitable boundary conditions I ran my case and after moving about the third way of my simulation, the running had some errors and stopped, I do not why? .. can any body helps me please because I am not that good in analyzing these kinds of errors. Following is what I got in my log file and later what I got when I tried to visualize the results I got so far.....
Sandy,
--> FOAM Warning :
From function Time:perator++()
in file db/Time/Time.C at line 1010
Increased the timePrecision from 425 to 426 to distinguish between timeNames at time 0.00334471
MULES: Solving for alpha1
Phase-1 volume fraction = 0.0996296 Min(alpha1) = -7.15878e-18 Max(alpha1) = 1
--> FOAM Warning :
Increased the timePrecision from 426 to 427 to distinguish between timeNames at time 0.00334471
Phase-1 volume fraction = 0.0996296 Min(alpha1) = -6.92445e-18 Max(alpha1) = 1
--> FOAM Warning :
Increased the timePrecision from 427 to 428 to distinguish between timeNames at time 0.00334471
DICPCG: Solving for p_rgh, Initial residual = 0.0701232, Final residual = 0.00347794, No Iterations 15
time step continuity errors : sum local = 4.77586e-08, global = 8.31991e-20, cumulative = -0.0192578
DICPCG: Solving for p_rgh, Initial residual = 0.0102893, Final residual = 0.000508149, No Iterations 49
time step continuity errors : sum local = 7.46065e-09, global = 1.01329e-19, cumulative = -0.0192578
DICPCG: Solving for p_rgh, Initial residual = 0.00247839, Final residual = 9.2203e-08, No Iterations 539
time step continuity errors : sum local = 1.35495e-12, global = -6.14748e-20, cumulative = -0.0192578
ExecutionTime = 65764.4 s ClockTime = 65868 s
Courant Number mean: 0.000206534 max: 0.536392
Interface Courant Number mean: 1.24362e-05 max: 0.122753
deltaT = 4.82732e-22
--> FOAM Warning :
Increased the timePrecision from 428 to 429 to distinguish between timeNames at time 0.00334471
Time = 0.003344711717348729240750770941303926520049571990 966796875
--> FOAM Warning :
Increased the timePrecision from 429 to 430 to distinguish between timeNames at time 0.00334471blowing up
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4 void Foam::MULES::limit<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double, int, bool) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/interFoam"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
and when I tried to visualize it I got this:
atheel@l031:~/interFoamvalidation/laminar/liquidjet111$ paraFoam
created temporary 'liquidjet111.OpenFOAM'
Find an unexpected case. The input polyhedron cell may not be a water tight or the polygonal faces may not be planar. Contouring will continue, but this cell may not be processed correctly.
sandy13 is offline   Reply With Quote
Old   April 17, 2013, 21:22
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Typical MULES blow-up, try decreasing the time-step and/or increasing the number of nAlphaSubCycles.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   May 5, 2015, 08:16
Post interFoam running blowing up
Sam_CFD is on a distinguished road
Dear Foamers,
I am simulating a case which involves 2 phases with very high pressure difference from inlet to outlet using interFOAM.
I have set up the case and trying to run the case but its blowing up.
Mech check was ok. setFields was perfect.
I have attached the case set up and also log file.
Please guide me where its going wrong.
Regards,
Sam
Sam_CFD is offline   Reply With Quote
interFoam simulation blowing up mgdenno OpenFOAM 55 November 2, 2018 21:20
InterFoam / InterDyFoam running problem anon_c OpenFOAM Running, Solving & CFD 1 August 26, 2009 04:54
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
InterFoam problem running parallel vatant OpenFOAM Running, Solving & CFD 0 April 28, 2006 20:22
