InterPhaseChangeFoam problem with OpenFOAM 2.2.0
Old   April 13, 2013, 17:44
Default InterPhaseChangeFoam problem with OpenFOAM 2.2.0
Stefano Gaggero
Mashiro5 is on a distinguished road
Dear OpenFOAM users,
I'm a beginner OpenFoam user and I would like to share my problems with the InterPhaseChangeFoam solver.
I try to compute the cavitating flow around a simple NACA wing profile but the results obtained with teh last version of OF are not so encouraging.As you can see from the attached figures with OF2.2.0 tha fraction of vapor is very unstable. Moreover, during the entire simulation (abt. 3 s with a prescribed Courant number of 0.5) there are no cells completly filled with vapor (generally the minimun value of alpha1 is around 0.2).
Instead, when I moved back to OF2.1.1 using the same parameters, results are extremely better: during the simulation it is possible to recognize the re-entrant jet, the cavity bubble at the profile leading edge is more stable and match pretty well teh available experimental observations.
I would like to know if it is my unexperince the reason of these poor quality results or if some of you has already faced this kind of problems with the latest version of OF.
Thanks in advance,
Stefano
Mashiro5 is offline   Reply With Quote
Old   April 15, 2013, 05:01
Sandy Lee
sandy is on a distinguished road
Hi Stefano,
Could you explain why the numbers of dimension are different to p and k, for example
to p:
dimensions [1 -1 -2 0 0]
however, to k:
dimensions [0 2 -2 0 0 0 0]
Thanks
sandy is offline   Reply With Quote
Old   April 15, 2013, 09:35
Stefano Gaggero
Really I don't know.
I noted too the differences when declaring the dimensions of variables. I presumed that there was an error in the declaration and I changed it without any significant difference.
Stefano
Old   April 15, 2013, 11:10
Sandy Lee
Thank you for your quickly reply.
However, it seems I could not still get correct results---very high negative pressure and error pressure in stagnation point.
What about your results?
Old   April 16, 2013, 09:56
Sandy Lee
Hi Stefano, Do you know what is the meanings of "cAlpha"? How to give its numbers?
Old   April 18, 2013, 10:47
Sandy Lee
Hi Stefano , how can you get the correct results ? Please , Please help me out. Thanks.
No Wall pressure from OpenFOAM 2.2.0 musahossein OpenFOAM Post-Processing 11 October 1, 2013 15:08
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Problem with mpirun with OpenFOAM jiejie OpenFOAM 3 July 7, 2010 20:30
OpenFOAM 1.6 CreatePatch Problem TarifaPirata OpenFOAM Bugs 1 September 10, 2009 05:35
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
