Arthur Piquet
Rep Power: 13 ![]() |
hi,
I tried to run the pitzDaily tutorial for rhoPimpleFoam with LES turbulence model. I didn't change anything in it, Everything went well during the calculation but when I look up the solution with parafoam, the solution is "diverging". I tried the same case 1 month ago with the 2.1.0 and the case worked. Do you think it's a problem with the 2.2.0 ?? (you can try as well to see the problem) Thank you |
Rep Power: 0 ![]() |
Hi Arthur,
I was running a few cases with compresibleInterFoam and interFoam LES in openfoam 2.1 whereas these cases does diverge in openfoam 2.2 and I have no clue what's happening to them as they diverge suddenly while they are running perfect! Did you find any answer for your problem? P.S the cases now running with KOmega SST method. Thank you, |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
Checkerboarding problem in LES | Matteo85 | OpenFOAM Running, Solving & CFD | 3 | September 15, 2012 22:15 |
Checkerboarding problem in LES | Matteo85 | OpenFOAM Running, Solving & CFD | 0 | June 9, 2009 09:47 |
LES problem | Jose | FLUENT | 5 | September 29, 2003 05:04 |
problem while looping over cells in LES | Jimmy | FLUENT | 0 | September 5, 2002 15:33 |
