How to add bodyforce in momentum equation in viscoelasticFluidFoam?
Old   April 9, 2013, 11:03
Default How to add bodyforce in momentum equation in viscoelasticFluidFoam?
arshoon
arshoon is on a distinguished road
Hi,everybody...
I'm using a copy of free code(downloaded from http://sourceforge.net/projects/vffof21x/) to simulate
viscoelastic fluid in OpenFoam. The main function includes two decoupling equation: viscoelastic stress
equation and momentum equation, and I make a little change to momentum equation to add bodyforce to drive
the fluid. The equations are listed as follows:
1.UEqn(momentum equation) added bodyforce:
tmp<fvVectorMatrix> UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
+ fvc::laplacian(kappa/rho, U)
- fvm::laplacian((nus+kappa)/rho, U)
- fvc::div(sigmap/rho)
bodyforce
UEqn().relax();
solve(UEqn() == -fvc::grad(p));
2.TEqn(viscolastic equation):
gradU = fvc::grad(U);
tmp<fvTensorMatrix> TEqn
fvm::ddt(sigmap)
+ fvm::div(phi,sigmap)
nup/lambda1*(gradU + gradU.T())
+ (sigmap & gradU) + (gradU.T() & sigmap)
- (fvm::Sp(epsilon/nup*tr(sigmap), sigmap) + fvm::Sp(1/lambda1,sigmap))
- (xi/1)*( (gradU & sigmap) + (sigmap & gradU.T()) + (gradU.T() & sigmap) + (sigmap &
gradU))
// TEqn().relax();
solve(TEqn);
I start from 2D poiseuille flow,Initial U is set to zero, and the inlet and outlet of the tube are defined
as cyclic boundary.
I carried out two simulations with the same physic parameters but different mesh sizes, one is 100by50, the
other is 200by100, then I output the velocity profile in paraview.
To my huge surprise the maximum velocity differed a lot(U1:0.0052, U2:0.0093), and It seemed to be
impossible to be explained as space error...This problem bothered me a lot!!
I really wonder why??? Can anybody give me some advices?? Thanks very much!!
arshoon is offline   Reply With Quote
viscosity term in discetrization momentum equation hans-186 Main CFD Forum 4 April 1, 2013 14:34
solving the momentum equation in UEqn. callahance OpenFOAM 2 October 18, 2012 10:38
Derivation of k-e model from momentum equation CFDtoy Main CFD Forum 5 May 10, 2006 17:53
Guess Momentum add value Jackie Main CFD Forum 0 August 1, 2003 00:39
How to add a fixed force on momentum equation sun Phoenics 3 January 19, 2002 07:31
