Help neede for PressureInletOutlet BCs for buoyantBoussinesqSimpleFoam |
April 9, 2013, 07:56 |
Help needed for PressureInletOutlet BCs for buoyantBoussinesqSimpleFoam
Ryno Laubscher
Rep Power: 13 |
Hi Guys
I am relatively new to Openfoam and is busy learning the software I have already done a few of my own problems with success. Currently I trying to do the tuts I've done on Ansys during my studies at university. One tut is giving me a few problems, it will be much appreciated if someone could help me. The problem I am trying to simulate is 2D laminar flow around a heated vertical plate in air. The solver I am using is buoyantboussinesqsimplefoam and the RAS properties is set to laminar. The problem has the following boundaries: inflow, outflow, Symmetry, plate and front_back where the front_back is type empty and Symmetry is type symmetryPlane. The inflow should be a pressure inlet at ambient temperature T_amb and the outlet should be a pressure inlet outlet (to compensate for backward (reverse) flow) at T_amb. My question is could someone tell me how the 0/p and 0/U boundaries should be setup specifically the inlet and outlet BCs. Thank you in advance Last edited by RynoLaub; April 9, 2013 at 08:44. Reason: set to question |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 11:58 |
Understanding Code behind BCs | Linse | OpenFOAM Programming & Development | 8 | January 9, 2012 08:58 |
p & U outlet bcs for realistic wind inlet profile | stevek | OpenFOAM | 4 | July 19, 2010 02:29 |
BCs for Pressure Correction Equation (SIMPLE) | Bharath Somayaji | Main CFD Forum | 1 | March 1, 2006 06:12 |
Need Assistance: BCs for k-e model implementation | Dean Schrage | Main CFD Forum | 3 | August 11, 2001 01:02 |
