Problem of simulating of small droplet with radius of 2mm
Old   April 7, 2013, 12:57
Default Problem of simulating of small droplet with radius of 2mm
Guifan Li
liguifan is on a distinguished road
Good morning everyone,
I am trying to simulate a droplet of oil with radius of 2mm fall into a waster base with radius of 10cm and I use setField to initialize the droplet and water base, however, the after 0.4 seconds, the Delta T became some number around 1.5e-16 and the max courant number is around 0.13. ( I use the adjusted timestep), which make no sense to me.
Beside that, by viewing under paraview, I found that the droplet is not even a sphere(actually, I can't even see it). So I doubt the capacity of OpenFoam dealing with such a small droplet.
Can anyone give me some hint about why is this can and how to make it works?
Many thanks!
James
liguifan is offline   Reply With Quote
Old   April 7, 2013, 19:18
Guifan Li
Here is some log content I got from running the code
time step continuity errors : sum local = 0, global = 0, cumulative = 0
GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
deltaT = 0.00119048
Time = 0.0011904761904761905836
MULES: Solving for alphawater
water volume fraction, min, max = 1 1 1
MULES: Solving for alphaoil
oil volume fraction, min, max = 0 0 0
MULES: Solving for alphaair
air volume fraction, min, max = 0 0 0
Phase-sum volume fraction, min, max = 1 1 1
alphawater phase volume in zone internal = 508.292 ml
alphaoil phase volume in zone internal = 0 ml
alphaair phase volume in zone internal = 0 ml
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0236848, No Iterations 6
time step continuity errors : sum local = 1.64387e-05, global = -1.03465e-05, cumulative = -1.03465e-05
GAMG: Solving for p, Initial residual = 0.00074067, Final residual = 2.70641e-05, No Iterations 4
time step continuity errors : sum local = 7.79738e-07, global = -5.07037e-07, cumulative = -1.08535e-05
GAMGPCG: Solving for p, Initial residual = 2.96832e-05, Final residual = 8.98889e-09, No Iterations 3
time step continuity errors : sum local = 2.61834e-10, global = -8.68849e-12, cumulative = -1.08536e-05
ExecutionTime = 3.78 s
Courant Number mean: 6.82615e-06 max: 1.98889e-05
deltaT = 0.00139456
Time = 0.0025850340136054422366
water volume fraction, min, max = 1 0 1
air volume fraction, min, max = 0 0 1
air volume fraction, min, max = 4.35967e-09 0 1
air volume fraction, min, max = 8.71935e-09 -4.82588e-34 1
alphaair phase volume in zone internal = 4.43198e-06 ml
GAMG: Solving for p, Initial residual = 0.0381303, Final residual = 1.6858e-08, No Iterations 1
time step continuity errors : sum local = 5.30546e-05, global = -1.88254e-05, cumulative = -2.96789e-05
GAMG: Solving for p, Initial residual = 1.93613e-08, Final residual = 1.93613e-08, No Iterations 0
time step continuity errors : sum local = 6.10707e-05, global = -2.57188e-05, cumulative = -5.53978e-05
GAMGPCG: Solving for p, Initial residual = 2.94069e-08, Final residual = 2.94069e-08, No Iterations 0
time step continuity errors : sum local = 9.27571e-05, global = 9.34652e-06, cumulative = -4.60513e-05
ExecutionTime = 7.15 s
Courant Number mean: 0.000483287 max: 0.00911681
deltaT = 0.001635
Time = 0.0042200328407224962576
water volume fraction, min, max = 1.00001 0 1.00338
air volume fraction, min, max = -1.84692e-05 -0.00432414 1
Phase-sum volume fraction, min, max = 0.999996 0.993861 1.00071
water volume fraction, min, max = 0.999996 0 1.00406
air volume fraction, min, max = -3.56282e-06 -0.00427731 1
Phase-sum volume fraction, min, max = 0.999993 0.98778 1.00141
water volume fraction, min, max = 0.999978 0 1.00474
air volume fraction, min, max = 1.1343e-05 -0.00423064 1
Phase-sum volume fraction, min, max = 0.999989 0.981739 1.0021
alphawater phase volume in zone internal = 508.281 ml
alphaair phase volume in zone internal = 0.00576554 ml
GAMG: Solving for p, Initial residual = 0.0253438, Final residual = 1.98857e-08, No Iterations 1
time step continuity errors : sum local = 0.000105995, global = -6.39265e-05, cumulative = -0.000109978
GAMG: Solving for p, Initial residual = 0.0473882, Final residual = 0.000306761, No Iterations 1
time step continuity errors : sum local = 1.71959, global = 0.212659, cumulative = 0.212549
GAMGPCG: Solving for p, Initial residual = 1, Final residual = 1.51042e-08, No Iterations 6
time step continuity errors : sum local = 66013.1, global = -9015.75, cumulative = -9015.54
ExecutionTime = 10.62 s
Courant Number mean: 2.72432e+13 max: 1.83728e+17
deltaT = 4.4495e-21
--> FOAM Warning :
From function Time:perator++()
in file db/Time/Time.C at line 1029
Increased the timePrecision from 20 to 21 to distinguish between timeNames at time 0.00422003
Time = 0.00422003284072249625763
--> FOAM Warning :
Increased the timePrecision from 21 to 22 to distinguish between timeNames at time 0.00422003
air volume fraction, min, max = 1.1367e-05 -0.00402082 1
Phase-sum volume fraction, min, max = 0.999989 0.982154 1.0021
--> FOAM Warning :
Increased the timePrecision from 22 to 24 to distinguish between timeNames at time 0.00422003
water volume fraction, min, max = 0.999978 0 1.00461
air volume fraction, min, max = 1.14044e-05 -0.0040187 1
Phase-sum volume fraction, min, max = 0.999989 0.982243 1.0021
--> FOAM Warning :
Increased the timePrecision from 24 to 25 to distinguish between timeNames at time 0.00422003
water volume fraction, min, max = 0.999978 0 1.00459
air volume fraction, min, max = 1.14419e-05 -0.00401781 1
Phase-sum volume fraction, min, max = 0.999989 0.982245 1.0021
--> FOAM Warning :
Increased the timePrecision from 25 to 26 to distinguish between timeNames at time 0.00422003
alphaair phase volume in zone internal = 0.00581581 ml
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0306118, No Iterations 1
time step continuity errors : sum local = 2.68775e-06, global = 1.07034e-06, cumulative = -9015.54
GAMG: Solving for p, Initial residual = 8.01422e-06, Final residual = 4.91744e-08, No Iterations 1
time step continuity errors : sum local = 1.4253e-06, global = 1.00707e-07, cumulative = -9015.54
GAMGPCG: Solving for p, Initial residual = 5.0605e-06, Final residual = 1.33807e-08, No Iterations 1
time step continuity errors : sum local = 5.50534e-07, global = -8.27593e-08, cumulative = -9015.54
ExecutionTime = 14.02 s
Courant Number mean: 8.80955e-05 max: 0.05748
deltaT = 5.3394e-21
Time = 0.0042200328407224962576349547
--> FOAM Warning :
Increased the timePrecision from 26 to 27 to distinguish between timeNames at time 0.00422003
air volume fraction, min, max = 1.15751e-05 -0.00401756 1
Phase-sum volume fraction, min, max = 0.999989 0.982247 1.00223
--> FOAM Warning :
Increased the timePrecision from 27 to 28 to distinguish between timeNames at time 0.00422003
air volume fraction, min, max = 1.17348e-05 -0.0040173 1
Phase-sum volume fraction, min, max = 0.999989 0.982248 1.00254
--> FOAM Warning :
Increased the timePrecision from 28 to 29 to distinguish between timeNames at time 0.00422003
The Delta T become extremely small!
Old   May 27, 2014, 03:15
Martin K
Martin_K_lalelu is on a distinguished road
I know its been some time, but do you remember how to solve this problem? My single droplet also develops high Co so that the solver is not longer able to distinguish between different time steps and quits.
Regards
Martin
Martin_K_lalelu is offline   Reply With Quote
Old   May 27, 2014, 03:31
ahmed
ahmed_khatibs is on a distinguished road
this may be also due to mesh (deltat).
ahmed_khatibs is offline   Reply With Quote
Old   May 27, 2014, 04:30
T. Chourushi
Tushar@cfd is on a distinguished road
Check CFL criteria
Try reducing deltaT & increase mesh spacing depending upon your requirement
Tushar@cfd is offline   Reply With Quote
Old   June 3, 2014, 03:53
Martin K
Thank you!
small Gambit menu problem Subhash C. Bose FLUENT 5 July 18, 2010 07:20
Small problem in Gridgen - Database display Nico Pointwise & Gridgen 1 April 21, 2007 15:08
Radius leading edge problem Dadang CFX 1 April 20, 2004 02:35
About simulating laminar flow through small orific ncj Main CFD Forum 1 August 14, 2002 05:46
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
