Constant pressure despite temperature changes?
Old   April 6, 2013, 01:35
Default Constant pressure despite temperature changes?
Cameron
c_dowd is on a distinguished road
Hi.
I'm running a reacting foam case where I have edited the solver to ensure the density is constant. My problem is, I'm getting laminar flows (despite having an LES turbulence model turned on), which I can only attribute to the uniform pressure field in my results. The pressure field should not be uniform, as I have temperatures of up to 2000 in the flow.
As far as I can work out, this is in some way a result of my boundary conditions, yet no matter what combination I try I can't seem to solve it. I have a 3d cylindrical mesh with inlets on the sides and an outlet on the top. My inlets have a fixed velocity and zerogradient pressure, the outlet has zerogradient velocity and fixed pressure. I've tried various combinations of fixedfluxpressures and wavetransmissive BCs, yet still my pressure is perfectly uniform. Ideas?
c_dowd is offline   Reply With Quote
density, firefoam, pressure, reacting foam, temperature
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Pressure rising with temperature Koranten FLUENT 0 August 19, 2009 06:57
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
