assign polynominal function for water viscosity in OpenFOAM-2.2.x? |
March 30, 2013, 06:57 |
Pei-Ying Hsieh
Rep Power: 18 |
Dear OpenFOAMers,
I am wondering if anyone here has tried using polynominal function for water viscosity in OpenFOAM-2.2.x, specifically for compressibleInterFoam solver. I adapted the polynominal implementation from one of the tutorial cases, but, got the following error. Do I need to link compressibleInterFoam solver to specific libraries? Thanks! Pei-Ying --------------------------------------- hsieh@hillsdale:~/OpenFOAM/hsieh-2.2.x/run/compressibleInterFoam/newSensorManifold2x> compressibleInterFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-444404f722b4 Exec : compressibleInterFoam Date : Mar 30 2013 Time : 06:52:48 Host : "hillsdale" PID : 5711 Case : /home/hsieh/OpenFOAM/hsieh-2.2.x/run/compressibleInterFoam/newSensorManifold2x nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Constructing twoPhaseMixtureThermo Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport polynomial; thermo hPolynomial; equationOfState icoPolynomial; specie specie; energy sensibleEnthalpy; } --> FOAM FATAL IO ERROR: keyword rhoCoeffs<8> is undefined in dictionary "/home/hsieh/OpenFOAM/hsieh-2.2.x/run/compressibleInterFoam/newSensorManifold2x/constant/thermophysicalPropertieswater.mixture.equationOfSt ate" file: /home/hsieh/OpenFOAM/hsieh-2.2.x/run/compressibleInterFoam/newSensorManifold2x/constant/thermophysicalPropertieswater.mixture.equationOfSt ate from line 38 to line 38. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 402. FOAM exiting |
March 30, 2013, 07:14 |
Pei-Ying Hsieh
Rep Power: 18 |
HI,
I just found out that I made a mistake in the water properties dictionary. But, now, I have a new error: hsieh@hillsdale:~/OpenFOAM/hsieh-2.2.x/run/compressibleInterFoam/newSensorManifold2x> compressibleInterFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-444404f722b4 Exec : compressibleInterFoam Date : Mar 30 2013 Time : 07:12:59 Host : "hillsdale" PID : 6011 Case : /home/hsieh/OpenFOAM/hsieh-2.2.x/run/compressibleInterFoam/newSensorManifold2x nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Constructing twoPhaseMixtureThermo Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport polynomial; thermo hPolynomial; equationOfState icoPolynomial; specie specie; energy sensibleEnthalpy; } Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } --> FOAM FATAL ERROR: Supported energy type is ewater, thermodynamics package provides hwater From function water in file basicThermo/basicThermo.C at line 332. FOAM exiting -------------------------------------- Any suggestions will be highly appreciated. Pei-Ying |
March 30, 2013, 07:26 |
Pei-Ying Hsieh
Rep Power: 18 |
HI,
OK, I changed energy sensibleEnthalpy; to energy sensibleInternalEnthalpy; and now the case is running. I am not sure if this is the right thing to do. I am not faminar with the thermo lib. Pei-Ying |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
