Using a variable (increasing) inlet to get an easy convergence/initialization ?
Old   March 28, 2013, 03:32
Default Using a variable (increasing) inlet to get an easy convergence/initialization ?
HECKMANN Frédéric
fredo490 is on a distinguished road
Dear all,
I'm running some simulations with rhoSimplecFoam (k-epsilon, Air) and I encounter some convergence / initialization problems. I mostly run my case at Mach 0.3 and 0.4 and I often get divergence even with simple geometries such as Naca Airfoils or Cylinders.
I tried different techniques:
- initialize the flow with a potentialFoam
- initialize the velocity internalField at different speed (0 to 80m/s)
- play with the under relaxation numbers ...
- using upwind scheme
- use different meshes (structured, unstructured, yPlus from 0.1 to 30,...)
After many tries, I found that a good way to avoid divergence and get convergence is to slowly increase the inlet velocity value ! For example, I start at 2m/s, then 5m/s, then 10m/s and so on until the actual velocity. However, this technique is "slow" and requires some manual change.
First, is this "initialization" ok ? I mean, I didn't see anybody using such a technique, maybe there is a problem I don't know about.
Second, is there a way to make this automatically ? I found this link but it looks old and unusable in OF2: http://www.idurun.com/?p=512
My inlet is:
alphat:
        type            calculated;
        value           uniform 0;
epsilon:
        type            fixedValue;
        value           uniform 2.15e-1;
k:
        type            fixedValue;
        value           uniform 1.6e-2;
mut:
        type            calculated;
        value           uniform 0;
p:
        type            zeroGradient;
T:
        type            fixedValue;
        value           uniform 281.4;
U:
        type            fixedValue;
        value           uniform (81.02 0 0);
My outlet is:
alphat:
        type            calculated;
        value           uniform 0;
epsilon:
        type            inletOutlet;
        inletValue     uniform 2.15e-1;
k:
        type            inletOutlet;
        inletValue     uniform 1.6e-2;
mut:
        type            calculated;
        value           uniform 0;
p:
        type            fixedValue;
        value           uniform 95650;
T:
        type            inletOutlet;
        inletValue     uniform 281.4;
U:
        type            inletOutlet;
        inletValue     uniform (81.02 0 0);
My wall is:
alphat:
        type            alphatWallFunction;
        value           uniform 0;
epsilon:
        type            compressible::epsilonWallFunction;
k:
        type            compressible::kqRWallFunction;
mut:
        type            mutkWallFunction;
        value           uniform 0;
p:
        type            zeroGradient;
T:
        type            zeroGradient;
U:
        type            fixedValue;
        value           uniform (0 0 0);
My internalFiel is:
alphat:
        value           uniform 0;
epsilon:
k:
mut:
        value           uniform 0;
p:
T:
U:
fredo490 is offline   Reply With Quote
Old   March 28, 2013, 10:04
Olivier
olivierG is on a distinguished road
hello,
Which field is diverging ? My guess would be turbulence model :
=> try turbulentIntensityKinetics... for k, and turbulentMixingLenght... for epsilon, and relax k,epsilon (if steady solver).
If you would to use a ramped velocity inlet, take a look at flowRateInletVelocity or uniformFixedValue, and specify a velocity changing in time (or iteration), like:
type uniformFixedValue;
uniformValue table
(0 (0 0 0))
(100 (100 0 0))
which start with 0 velocity at time 0, then grow to Ux=100m/s at time 100, and stay after that (since outOfBound clamp; is the default).
regards,
olivier
olivierG is offline   Reply With Quote
Old   March 28, 2013, 14:54
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
Look at the motorbike tutorial (Allrun), which uses potentialFoam to get the fields initially, then it runs the actual solver. Would this work for you?
MY BAD: You alread tried this.
JR22 is offline   Reply With Quote
Old   March 29, 2013, 04:23
HECKMANN Frédéric
Thx Olivier for your advices.
0) the diverging field is most of the time the pressure that leads to a Floating Point Exception (caused by the thermo model).
1) I've tried to change my k and epsilon settings (inlet and relax number) but it doesn't change anything.
2) The technique of the Table works well but I need many steps to reach my final velocity.
3) I've also tried to use the flowRateInletVelocity inlet but it also often diverge after only 2 or 3 iterations (the pressure starts to diverge first). Moreover, using this kind of Inlet, I get some strange oscillation of the pressure/density through my domain. It's like a wave going from the inlet to the outlet and coming back (once my pressure inlet > pressure outlet and then two iteration later it is pressure inlet < pressure outlet and so on).
Old   March 29, 2013, 06:00
HECKMANN Frédéric
To make the things simple, here is my current case (3.8 MB) :
http://www.fredo490.fr/public/rhoSim...der_Vinlet.zip
It is a structured 4 inch cylinder at 81.02m/s (95650 Pa and 8.2°C).
Old   April 2, 2013, 07:22
Olivier
hello,
You may try to modify the outlet BC:
-p : totalPressure
- U pressureInletOutletVelocity (or pressureInletVelocity / pressureDirectedInletVelocity / ...)
regards,
olivier
Old   April 2, 2013, 10:02
HECKMANN Frédéric
thx for your advice.
For those who want, I found a good source for the table inlet: http://www.openfoam.org/version2.1.0...conditions.php
Also, I found that using a "Laplacian schemes linear limited 0.5" helps a lot.
Old   April 9, 2014, 09:01
Tobias Adam
Tobias Adam is on a distinguished road
is it possible to use such table options for the SRF or MRF - options in order to increase the rotational speed?
Tobias Adam is offline   Reply With Quote
Old   April 9, 2014, 10:35
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Well,
in case of MRF you can do it cause omega is defined as follows:
//- Angular velocty (rad/sec)
autoPtr<DataEntry<scalar> > omega_;
while in SRF there's no such possibility as RPM is defined as
//- Revolutions per minute
scalar rpm_;
Surely you can make your own SRFModel where RPM is simillar to omega in MRFModel.
alexeym is offline   Reply With Quote
OpenFoam-1.6-ext Allwmake compilation error - one last barrier Pat84 OpenFOAM Installation 15 July 25, 2012 22:49
Turbulent flow through a pipe with variable inlet velocity lobstar OpenFOAM Running, Solving & CFD 8 March 28, 2012 12:15
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure jola FLUENT 1 May 5, 2011 15:33
Inlet table in STAR-CD Sachin Siemens 1 March 26, 2008 11:22
Variable velcity at inlet John FLUENT 1 April 7, 2003 12:34
