how to add spring/damping effect to connect two moving body
Old   March 27, 2013, 10:47
Default how to add spring/damping effect to connect two moving body
Teemo
Teemo is on a distinguished road
Dear FoAMers,
I would like to connect these two moving parts together by a spring , how can I achieve it in OPENFOAM?
Your suggestion will be appreciated.
Regards,
T
Teemo is offline   Reply With Quote
Old   March 27, 2013, 10:50
Teemo
Old   March 27, 2013, 12:17
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Teemo,
I my version of OF (1.6-ext) you can find the following constraints for mesh motion here:
/src/postProcessing/functionObjects/forces/pointPatchFields/derived/sixDoFRigidBodyMotion/sixDoFRigidBodyMotionRestraint
The linear spring seems like a good choice for the initial investigation.
I have no idea on how they are working, though I know that the are also present in the more recent releases of OF.
Good luck,
Niels
ngj is offline   Reply With Quote
Old   March 27, 2013, 12:41
Teemo
Thanks Niels,
I will give it a try.
Regards,
T
Old   March 27, 2013, 13:23
Teemo
hello again,
I have looked into the linear spring file and for its setup:
//- Anchor point, where the spring is attached to an immovable object
point anchor_;
//- Reference point of attachment to the solid body
point refAttachmentPt_;
//- Spring stiffness coefficient (N/m)
scalar stiffness_;
//- Damping coefficient (Ns/m)
scalar damping_;
//- Rest length - length of spring when no forces are applied to it
scalar restLength_;
it seems that one end of the spring should be fixed, but for my case, i need both ends move with the floaters, any idea?
Regards,
T
Old   November 10, 2014, 11:09
Teng
tyoung is on a distinguished road
Hi Teemo,
I am currently facing similar situation and would like to know whether you had any luck on it?
Regards
tyoung
tyoung is offline   Reply With Quote
Modify NS eqns for moving body Northstar Main CFD Forum 3 March 9, 2006 01:53
about Cart3d and moving body Tiger Main CFD Forum 0 July 13, 2005 07:12
Moving Body Grid Question Matt Main CFD Forum 5 September 13, 2004 01:45
HELP: unsteady solving of Moving body in fluid Quain Tchew Main CFD Forum 1 May 22, 2003 00:21
Test for 3D moving body Anvar Gilmanov Main CFD Forum 4 May 1, 2002 12:34
