Steady-State and Transient Solvers
Like Tree11Likes
Old   April 9, 2018, 14:02
Default Piso solver to solve for a steady state solution
  #21
sai Giridhar
sai993 is on a distinguished road
Hello all,
I was hoping to get some help with a problem. I have modified the pisoFoam solver to add a constant body Force. And the set up i made to steady the flow over a flat plate. The velocity never reaches a steady value the solution osilates every 10sec to 20sec.
set up for p
inlet
fixed value
value uniform 0;
outlet
fixed value
value uniform 0;
set up for velocity
zeroGradient
bodyForce 4.4e-3;
can some help me. I am not sure if this form is even active i will add all the details if someone can help. i have spent lot of time this so i am really need some help
thanks
sai
sai993 is offline   Reply With Quote
Old   May 8, 2021, 08:09
Arijit Saha
ari003 is on a distinguished road
Originally Posted by NickolasPl View Post
Greetings Thomas,
The terms steady state and transient have to do on if time is a parameter or not (very roughly). This has to do with the phenomena that you are studying.....if your physical flow does not change over time then you can see it as steady state. So in either case you must know before you do the simulation if your "real" flow is steady or transient and then procceed with the solvers you talked about. Poiseuille flow for example is treated as steady state.
Regards,
Nickolas
By real flow do you mean the flow after some significant time step?
ari003 is offline   Reply With Quote
pisofoam, simplefoam, steady-state, transient
Steady State Vs Transient answers Kushagra CFX 25 July 23, 2017 04:20
error message cuteapathy CFX 14 March 20, 2012 07:45
Steady state vs. mean transient analysis of flow behind a circular cylinder Heini Main CFD Forum 1 June 9, 2011 07:47
Mass Diffusion: Transient and Steady State BC rval CFX 3 November 19, 2008 01:52
Transient vs Steady State Adam CFX 1 April 12, 2007 12:34
